Old 03-05-2009, 04:20 PM   #1
1965 26' Overlander
san luis obispo , California
Fresh Water Tank Size Issues
Hi, we are in the process of restoring a 65 overlander and are having trouble locating water tanks that fit our specifications. We have been warned against building our own out of fiberglass, and the cost of having custom made tanks is out of our budget. Does anyone have advice
Jessica & Joseph
jespa80 is offline   Reply With Quote
Old 03-05-2009, 04:29 PM   #2
Jessica & Joseph
Fiberglass tanks cannot be used for drinking water.
Old 03-05-2009, 05:05 PM   #3
1965 26' Overlander
Hi Andy, I believe I just spoke to a woman who works at your store, she informed me that the vin number i gave her was actually for a 68 overlander even though the registration i was given says it's a 65. The dimensions for the fresh water tank she gave me are 24x52x6, it appears to me that the depth is only 5 inches, so how does the tank fit into to the frame? Is it installed so that the floor is raised up an inch under the front window? Any help or answers would be appreciated. Jessica & Joseph
Old 03-05-2009, 05:10 PM   #4
That tank fits underneath the front lounge, as it was originally designed to do, no problem.
Old 03-05-2009, 05:15 PM   #5
1965 26' Overlander
You would'nt happen to have or know where i can find a diagram on how this was originally installed would you?
Old 03-05-2009, 06:16 PM   #6
Sorry, I do not.
But the front of the front lounge was on the floor. Then part way back, the lounge was elevated so thet the tank water would fit.
The rear part of the lounge was supported at the rear corners.
I can e-mail a photo of that tank to you, if you wish.
Old 03-06-2009, 11:20 AM   #7
68-69 water tank.
The correct original tank measures 6 x 24 x 51 inches, and is 30 gallons.
They come with all the fittings and gauge connections already installed.
We can e-mail a photo to you, if you wish.
Old 03-06-2009, 02:40 PM   #8
walter1's Avatar
1964 22' Safari
Foresthill , California
I replaced the fresh water tank in my 64 Safari with a new tank from the original manufacturer. They had various sizes, I bought a 40 gallon tank that fit just right under the gaucho. I had to make new hold down brackets/straps. Works great.
They are in Northern California somewhere. I can find company info if you want it.
walter1 is offline   Reply With Quote
Old 03-06-2009, 06:10 PM   #9
kevin barnes's Avatar
1968 26' Overlander
Delta , BC
Images: 36
I am parting out a 68 Tradewind, I have that tank if you are interested.
kevin barnes is offline   Reply With Quote
Old 03-06-2009, 07:37 PM   #10
1965 26' Overlander
A picture would be great
Jessica and Joseph
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Fresh water tank size 71 Overlander photon Waste Systems, Tanks & Totes 2 08-13-2007 10:59 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
Fresh H2O Tank Size?? RiskIt Fresh Water Systems 6 05-16-2005 01:23 PM
