Old 07-12-2014, 06:16 PM   #1
1962 22' Safari
Corpus Christi , Texas
Fresh water tank removal
New to this so bear with me. We have just acquired a 63 safari. We have it gutted down to the floor, which is next. The thing standing in our way is the fresh water tank. I have the pump, not planning n using it again. The tank holds water for sure. As soon as I disconnected the lines it started draining, no clue how long that water was in there. Problem is the inlet that runs out of the trailer into the tank won't turn. On the outside it has a 90 degree which is stopping me from just pulling it in. Any ideas/ tricks. Been thinking about just cutting it off, problem is then it's still in the tank. It's holding up getting the shell off, so any ideas are really appreciated.
RevandDoc is offline   Reply With Quote
Old 07-12-2014, 06:27 PM   #2
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Some pictures would help maybe.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 07-12-2014, 08:21 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My 66 is a plastic tank with a water pump. I think the 62s have a steel tank that uses air pressure to deliver the water. Maybe the water inlet pipe is welded to the tank. Mine just uses a flex hose with hose clamps, but there is no pressure in the tank.
Hang tight for a few days. Some vintage Airstreamer will answer your question soon. And yes, a picture would be very helpful.
David
Old 07-12-2014, 10:29 PM   #4
1962 22' Safari
I'll try and get some pics tomorrow. This is a metal (steel) tank. I just have to get it out of thee to get all the flooring and shell off. I can cut through the 90 but that doesn't leave me much to work with to get out of the tank.
Old 07-12-2014, 11:37 PM   #5
reinergirl's Avatar
Hollis , New Hampshire
Those tanks are typically rotted at the bottom, usually replaced with a plastic tank ...m
reinergirl is offline   Reply With Quote
Old 01-30-2015, 08:15 PM   #6
1960 22' Safari
Johnson City , Tennessee
Did you succeed in removing the tank? I aim to remove mine tomorrow.
teilhet is offline   Reply With Quote
Large fresh water tank plug-removal erikk Fresh Water Systems 0 06-22-2012 05:58 PM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-02-2011 12:51 AM
Removal of 1973 fresh water tank Belegedhel Fresh Water Systems 6 08-05-2011 08:32 AM
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 11:46 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 11:50 AM
