Old 09-07-2003, 05:16 PM   #1
srgntpepper's Avatar
Fresh Water Tank Questions
Hello all I am replacing the plumbing in my 63 Safari, The PO has removed the water tank which I understand was a pressurized system. I am looking for replacement tank, but I am putting in a pump and a "conventional" plumbing system. Anyone know the proper size tank that would work as a replacement, and where to get one???? Thanks alot ,
Don
srgntpepper is offline   Reply With Quote
Old 09-08-2003, 09:14 AM   #2
The original 30 gallon tank that Airstream used from 64 to 68 works well.
Old 09-08-2003, 04:14 PM   #3
hey thanks andy, do you sell the replacement? Also any suggestions on re sealing a leaky outer skin seam?
Old 09-10-2003, 07:32 PM   #4
dwinick's Avatar
1958 22' Flying Cloud
1948 16' Wee Wind
Ada , Michigan
fresh water tank replacement source
Call Inca plastics and get it right from the source. All they make is rotomold tanks.
They supplied Airstream for years and have replacements. I believe a 30 gal[their replacement size is 29 gals I think] is around 135 bucks.
Their number is: (909)923-3235
A politician is a man who will double cross that bridge when he comes to it.
Oscar Levant
dwinick is offline   Reply With Quote
Old 10-18-2003, 02:22 PM   #5
duckrunner's Avatar
pump model
I too am going to install (shortly) a freshwater tank for my silver buddy (1967 Sovereign). Do any of you have reccomendations for a water pump? Thanks--
JP
Jimmy D. Pippin
1967 Sovereign 31'
"Do or do not; there is no try."
--Yoda
duckrunner is offline   Reply With Quote
Old 10-18-2003, 05:51 PM   #6
Images: 59
Water tanks
You can also get tanks from Accu-tankAccuTank RV water tanks
I just got a greywater tank from them and it looks good. They will add fittings wherever you want. Similar to Inca. If Inca doesn't have the size you want (they have hundreds) try Accu-tank. Located in N. California.
Old 10-19-2003, 11:03 AM   #7
gerbermania's Avatar
Hello JP,
There are a few variable-speed water pumps out now that do not require accumulator tanks to deliver smooth water flow. These also do not cycle as often, and can be extremely quiet.
Shurflo Smart Sensor 5.7
Flojet Sensor VSD pump, 3.7 gpm
Christopher
gerbermania is offline   Reply With Quote
Fresh water tank leak Flex Fresh Water Systems 3 09-30-2004 04:25 AM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 12:37 PM
Problem Filling Fresh Water Tank DaveJ Fresh Water Systems 8 10-14-2003 05:36 PM
Leaky fresh water tank nellie the elephant Fresh Water Systems 3 10-13-2003 02:12 PM
Fresh water tank - slow drip drboyd Fresh Water Systems 5 07-24-2003 07:01 PM
