Old 08-16-2011, 06:41 PM   #1
1974 25' Tradewind
Berryville , Virginia
fresh water tank plumbing
I am redoing a 74 trade wind land Yacht , the plumbing was changed. I have pulled the tank which looks good but I am not sure how to re plumb it. I am guessing the 1/2" outlet on the bottom is the supply which runs to a filter and to the pump. The other two fittings are 3/8 " nipples on the top either side of the center of the tank. I read that these were vents which are meant to T and run somewhere to the underside of the sink. could someone elaborate on this? AS I say I have nothing to go on. I have the old pump sitting there which I plan on replacing with a new quiet one.
Is 1/2 pex adequate, I am guessing it would be, since none of these fixtures draw much.
batt is offline   Reply With Quote
Old 08-16-2011, 07:07 PM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Here is the fresh water page from the service manual for a 25'.
It doesn't show the two relief hose things. they come up from the tank and come together with a T then the one line goes on the nipple thing directly underneath the input hose where the water comes in.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Removal of 1973 fresh water tank Belegedhel Fresh Water Systems 6 08-05-2011 07:32 AM
Fittings for fresh water tank gwchitty Fresh Water Systems 0 06-05-2011 04:27 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
