had a minor leak on my fresh water tank, here is what i found.
the drain plug and petcock were shot. the plug disintergrated, basicly falling out when i removed the inspection cover. the threads were completely gone.
never seen plastic plumbing parts do anything like this???
the petcock was brittle from age and was cracked around the mounting flange.
got a 1 1/2" cleanout plug from the local mom and pop hardware store, need to get a new petcock. a local dealer has these, just need to get over and pick one up.
lubricated the treads of the plug with dielectric silicone grease.
Great pics John. I downed a few of those on the 4 day fishing trip that started June 27. Bass and catfish were caught and what a grand cookout we had that Saturday night along with boiled shrimp. One of the guys caught a flathead catfish weighing 13 lbs. While not the biggest (35-50 lb. cats are caught) it sure was good eating. The trailer airconditioning worked fine all 4 days in contrast to last year's fiasco the next site over.
__________________ Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
good deal on the fishing trip! gotta make some time to get away and do that. haven't been fishing since there was ice!
wingfoot,
don't worry to much, it is a very easy repair. at least if it leaks it just runs out of the pan. cant wreck much unless you leave it go too long. if it ain't leaking it is most likely o.k.
side note, when i get everything buttoned up i plan on wire brushing the pan and painting it with some cold galvanizing paint.
JOHN, THANKS FOR THE INFO RE THE PETCOCK VALVE. I HAVE A 1985 SOVEREIGN AND THE PLASTIC VALVE IS ALMOST GONE. I CAN'T FIND AND SUCH THING AND HAVE BEEN LOOKING. COULD YOU PICK ME UP TWO....I WOULD PAY IN ADVANCE. THANKS........BIG H JHDUNN1@AOL.COM
Had to go back to one of your 2003 posts on freshwater tank repairs. My trailer is a 1987 and the large drain plug has finally disintegrated enough to where it started to leak last month.
I called Kim at Airstream parts and she gave me the part number 600-155 for a replacement plug. Guess this happens to 15-20 year old water tanks? Called my Airstream dealer, gave them the number and the plug will be here next wednesday.
Apparently the plug has been a problem because they stock a replacement and it is a black plastic vs. the yellow/white hard plastic that is failing.
