Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 06-30-2003, 07:52 PM   #1
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
fresh water tank plug and valve repair
hi all,
had a minor leak on my fresh water tank, here is what i found.
the drain plug and petcock were shot. the plug disintergrated, basicly falling out when i removed the inspection cover. the threads were completely gone.
never seen plastic plumbing parts do anything like this???
the petcock was brittle from age and was cracked around the mounting flange.
got a 1 1/2" cleanout plug from the local mom and pop hardware store, need to get a new petcock. a local dealer has these, just need to get over and pick one up.
lubricated the treads of the plug with dielectric silicone grease.
here are some pics...
john
Old 06-30-2003, 07:54 PM   #2
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
old and new plugs
here they are for your viewing enjoyment
Name:	old and new plug.jpg
Old 06-30-2003, 07:55 PM   #3
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
drain petcock
and the soon to be replaced petcock...
updates to follow...
john
Name:	drain petcock.jpg
Old 06-30-2003, 10:18 PM   #4
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Great pics John. I downed a few of those on the 4 day fishing trip that started June 27. Bass and catfish were caught and what a grand cookout we had that Saturday night along with boiled shrimp. One of the guys caught a flathead catfish weighing 13 lbs. While not the biggest (35-50 lb. cats are caught) it sure was good eating. The trailer airconditioning worked fine all 4 days in contrast to last year's fiasco the next site over.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-30-2003, 10:45 PM   #5
Profile:
Good Photos. I just replaced the petcock on my 87 Sovereign. It cracked just as you described while I was disinfecting tank.
I did not remove bottom cover plate. I saw no moisture so I didn't touch. Now you have me nervous.
wingfoot is offline   Reply With Quote
Old 07-01-2003, 05:37 AM   #6
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
craig,
good deal on the fishing trip! gotta make some time to get away and do that. haven't been fishing since there was ice!
wingfoot,
don't worry to much, it is a very easy repair. at least if it leaks it just runs out of the pan. cant wreck much unless you leave it go too long. if it ain't leaking it is most likely o.k.
side note, when i get everything buttoned up i plan on wire brushing the pan and painting it with some cold galvanizing paint.
john
Old 07-07-2003, 03:53 PM   #7
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
update
here is the $1.49 valve.
so cheap i bought two so i have a spare!
john
Old 07-07-2003, 03:55 PM   #8
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
finished!
here is the installation after some cold galvanizing paint and stainless steel screws.
not bad in all, $4.50 total and three beers!
john
Name:	valve finished.jpg
Old 07-07-2003, 07:34 PM   #9
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Nice installation John. Funny, that's how I measure repair time too - in number of beers.
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 07-16-2003, 12:00 PM   #10
skipj's Avatar
Profile:
Did you purchase the petcock from a Airstream Dealer?
SkipJ
89 25' Excella
92 B-van
skipj is offline   Reply With Quote
Old 07-16-2003, 05:56 PM   #11
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
nope!
got it froma mom and pop rv place.
don't know if it is an airstream only part. i could be because the owner has a couple of vintage trailers.
for a buck and a half, i'd bet it isn't a airstream only part!
john
Old 06-09-2004, 10:43 AM   #12
Profile:
JOHN, THANKS FOR THE INFO RE THE PETCOCK VALVE. I HAVE A 1985 SOVEREIGN AND THE PLASTIC VALVE IS ALMOST GONE. I CAN'T FIND AND SUCH THING AND HAVE BEEN LOOKING. COULD YOU PICK ME UP TWO....I WOULD PAY IN ADVANCE.
THANKS........BIG H JHDUNN1@AOL.COM
BIG H is offline   Reply With Quote
Old 06-09-2004, 06:33 PM   #13
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
big h
got one left in my stash, lemme run out and see if i can get you some this weekend.
if i can't find any you are welcome to my extra one.
john
you call them ferrets, i call them weasels.
Old 04-05-2006, 01:59 AM   #14
Profile:  1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Freshwater tank plug
John HD,
Had to go back to one of your 2003 posts on freshwater tank repairs. My trailer is a 1987 and the large drain plug has finally disintegrated enough to where it started to leak last month.
I called Kim at Airstream parts and she gave me the part number 600-155 for a replacement plug. Guess this happens to 15-20 year old water tanks? Called my Airstream dealer, gave them the number and the plug will be here next wednesday.
Apparently the plug has been a problem because they stock a replacement and it is a black plastic vs. the yellow/white hard plastic that is failing.
Old posts do pay
wingfoot321 is offline   Reply With Quote
Winterizing Tips niftypkg Winterizing, Storage, Carports & Covers 144 01-22-2009 08:06 AM
Another question - Drain valves kamadeca Waste Systems, Tanks & Totes 12 07-24-2004 12:29 PM
How cold for winterizing? ipso_facto Our Community 27 12-03-2003 05:56 PM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 10:02 AM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 09:14 PM
