I am also having fits with the valve as well. The original valve started leaking where the line between the valve and the tank was crimped onto the valve barb. I replaced the valve and hose with a JR Products 3.8-1/2 inch drain cock part no 03182 and 1/2 inch reinforced hose from the hardware store. I had no trouble clamping the hose to the tank barb, but have tried twice to get the hose tight on the valve barb and it still leaks. I have never had so much futile work tied up in less than $5 worth of parts! What is the best type of hose and clamp to use here? It also is almost impossible to get to the clamp adjacent to the valve, so I plan to attach the hose before installing into the tank cover-even it it means expanding the hole behind the valve. Thanks, Julian H.
