Old 09-15-2019, 02:49 PM   #1
hjnj's Avatar
2018 33' Classic
Mendham , New Jersey
Fresh water tank overflowing when city water connected
We parked our ‘18 Classic 33 in a campground and left it for a few days. City water was hooked up and turned on as was electricity. 2 days later, we got a call from the owner letting us know that water was “coming out of our trailer!”
We braced for the worst, but to our pleasant surprise, the trailer was completely dry inside. When I turned the water back on, water started running out of the fresh water tank filling inlet ventilation hole. When I turned the hose off, it stopped again.
Has anyone here had this situation? It appears that there must be a valve that is not working properly between the city water system and the fresh water tank. Any advice would be appreciated.
hjnj is offline   Reply With Quote
Old 09-15-2019, 02:59 PM   #2
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
Yes, I have had the same problem. Disconnect the AS from all power and put the Battery switch to “store”.
The water check valve/ pump will reset itself while disconnected from all power.
Plug power back in and connect city water. Keep an eye on fresh water level. That should take care of the problem most of the time.
When connected to city water I do-not turn on the pump. I use one or the other but not both st the same time.
Stay Calm and Stream On!
HHPJ is offline   Reply With Quote
Old 09-15-2019, 03:10 PM   #3
hjnj's Avatar
2018 33' Classic
Great. I will try that. We won’t have our trailer again for about 3 weeks, but I will definitely try that and post
my results. I meant to add to the first post that the water pump was off when this happened. Thanks very much!
Harry
Old 09-15-2019, 04:38 PM   #4
Long Island , New York
Never never leave your trailer alone with the city water connected.
Never.
"pump check valve bad tank overflowing" search results FYI:
https://www.google.com/search?q=pump...com&gws_rd=ssl
When back at trailer, turn pump on and off a few times [city water off], and hopefully the pump's check valve will clear itself of grit.
Always use an inline water filter when filling the tank and when using city water. Always.
https://www.amazon.com/Camco-TastePU...xpY2s9dHJ1ZQ==
Good luck,
Peter
PS -- Have you read your owner's manual carefully? Chances are good that it covers some of this IMO.
Old 09-15-2019, 04:47 PM   #5
This may not be complete and thorough advice IMO. See recent comment.
Also, the pump may need replacing IMO. TBD after steps just recommended to free up the grit, if possible.
Peter
Old 09-15-2019, 04:53 PM   #6
Cave Creek , Arizona
I just had this happen on our 2017 Classic while on a trip. I ran on the pump/tank overnight and the next day everything worked fine. The grit in the check valve must have cleared out. I always use a water filter so I’m not sure the cause
Pete B55
2017 Classic
2017 F-250
Pete B55 is offline   Reply With Quote
Old 09-15-2019, 06:39 PM   #7
I believe there have been reports of plastic shavings, from the manufacturing process, ending up in the water tank, due to lax worker habits about cleaning up properly. [IMO]
Old 09-15-2019, 11:11 PM   #8
hjnj's Avatar
2018 33' Classic
This is a great example of what a great site this is. I am not new to camping but I am always learning. Now that you point it out, it seems obvious to shut off the water supply to the trailer when not in use. Great advice from everyone - hopefully the simple steps mentioned will do the trick. I do always use an in-line water filter... Thanks everyone.
Old 09-16-2019, 04:33 AM   #9
Thanks for the update and good luck.
FWIW I am reminded of the John Wayne movie "True Grit" . . .
Peter
Old 09-16-2019, 10:12 AM   #10
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Just happened to me on my last trip.
Here is what I did:
Turned OFF the CITY water.
Used PUMP for the day
Turned ON the CITY water.
All was good.
I believe there was a debris in the tank that clogged the check valve in the pump.
What I plan on doing next is to add a secondary check valve from SHARKBITE between the fresh water tank and the pump. This should in theory prevent this from happening again.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
https://www.facebook.com/groups/2284022111820203/
cazual6 is offline   Reply With Quote
Old 09-16-2019, 10:36 AM   #11
harryk's Avatar
2005 31' Classic
Venice , Florida
You can add another / better check valve in the line on the feed line from the tank to the pump.
harryk is offline   Reply With Quote
Old 09-16-2019, 10:54 PM   #12
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Change pump inlet filters regularly and always use a filter the when filling the water tank and when hooked to city water. No water problems for 15 seasons.
guskmg
Fresh water tank fills when connected to city water DKGA General Repair Forum 6 02-05-2019 01:05 PM
Freshwater tank filled up while connected to city water Native143 Fresh Water Systems 16 07-01-2018 03:15 PM
City Water connected but still drawing from onboard fresh water tank holmesaz Fresh Water Systems 8 06-17-2016 07:44 AM
City water overflowing freshwater tank 223002104 Fresh Water Systems 11 03-18-2015 12:17 PM
City Water is Overflowing holding tank??? oldtrucksrul Fresh Water Systems 9 03-29-2014 11:38 AM
