Old 08-13-2017, 03:25 PM   #1
2016 28' Flying Cloud
Littleton , Colorado
Fresh Water Tank Overfilling
Is it possible the check valve on the water pump can fail, causing the city water connection to fill the fresh water tank? We are hooked up to city water and our fresh tank is full. We try to empty that tank and it continues to read full. Same thing when we use the pump. Even a long shower, using the pump, leaves the fresh water tank reading full. For the last 2 days, during the afternoon heat, the overflow valve at the tank fill location has been spilling water out of the trailer, down the side of the airstream and onto the ground Hpw can this happen.
Twotravelers is offline   Reply With Quote
Old 08-13-2017, 03:37 PM   #2
Titusville , Florida
Happens a lot. First, turn off the city connection completely or better disconnect. Turn water pump on and use the water in the Freash water tank until all gone. Then re connect with city water. Sometimes the check valve gets stuck. It isn't a real big problem and most of the time it will fix itself by turning on the Water Pump for a while. It may not happen again for months, other times it happens weekly.
Lauri
kendrick.l.j is offline   Reply With Quote
Old 08-15-2017, 03:56 PM   #3
Thanks. We followed your advice and the problem seems to have been resolved, at least for now. Nothing unwanted is going into the fresh water tank.
Old 08-15-2017, 04:02 PM   #4
Long Island , New York
Great news. If it happens again, just turn the pump on and off a few times, then hook up to city water and turn it on and off a few times, then the pump on and off few times. The grit usually dislodges itself.
To prevent grit from getting into your water system, you should always use an inline filter in the hose like this one:
https://www.amazon.com/Camco-40043-T...er+filter+hose
. . . whether you are filling the water tank OR using the hose for city water.
Although most folks consider it redundant, we also use an inline water pressure regulator like this.
https://www.amazon.com/Camco-40055-B...1WPXZFB5WRAFN7
Belts and suspenders . . .
Happy Trails!
Peter
Old 08-16-2017, 04:52 PM   #5
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Happy Trails!
Peter
I use a Valtera regulator, which is set at 50-55 psi. More flow to go.
MelGoddard is offline   Reply With Quote
Old 08-16-2017, 05:10 PM   #6
Lumberton , Mississippi
Send a message via ICQ to Lyman
Well glad to see someone else has seem problem as me. Sometimes hook up to city water a few days at a time and fresh water gauge stays okay. Sometimes hook up to city water it will fill up fresh water tank to point it will over flo at fill up point.
Shut off city water run pump a while than back on city will usually be okay. This is fine as long as on sewer site. But if not you would fill holding tank pretty fast. So if not on sewer than just use tank drain than refill. So far if this is only problem I have I am a happy camper. I have 2017 Classic model.
Lyman is offline   Reply With Quote
Old 08-16-2017, 05:13 PM   #7
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
No need to use an external water pressure regulator as all AS have them built into the city water inlet.
vintagemotor is offline   Reply With Quote
Old 08-16-2017, 05:18 PM   #8
Las Vegas , Nevada
Make sure that your water pump is OFF when connected to city water or it will fill the on board water tank and "leak" out of the overflow. I have even filled my on board tank from empty while at the RV park by leaving the pump on.
Old 08-16-2017, 10:31 PM   #9
1988 32' Excella
Robbinsville , New Jersey
You could install a ball valve by the pump so this can't happen.
Only issue is then you need to remember the valve when you switch between city water and tank.
Old 08-17-2017, 04:14 AM   #10
True about the built-in water pressure regulators in modern day AS, but they have been known to fail, and let pressure surges reach the plumbing system.
No harm in using a belt and suspenders approach, per this earlier comment:
Although most folks consider it redundant, we also use an inline water pressure regulator . . .
Old 08-17-2017, 04:19 AM   #11
In most AS, this would not be considered standard or normal IMO. With city water and pump on, the anti-back-flow check valve should still prevent water from back-flowing into the water tank. Some models may have intentionally offered this method for filling the tank, but most AS do not have it. [IMO]
Indeed, some AS owners manuals have specific instructions for turning the pump on, when the city water pressure is low, in order to get better flow for a shower etc..
Peter
Old 08-17-2017, 04:27 AM   #12
FYI in some models this would be a major pain in the neck, as the pump and filter area is quite inaccessible.
Preventing the failure of the check valve is the best medicine, by using an inline water filter to keep grit out of the check valve.
Old 08-17-2017, 05:25 AM   #13
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
At my Camp Host gig in Utah, the DNR staff recommended a regulator at the hydrant to protect your hose from the sometimes 110+ psi water pressure.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 08-17-2017, 07:41 AM   #14
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
While this is true, not placing a pressure regulator at the point where the hose connects to the campground spigot leaves the hose vulnerable. We were once in a campground in Utah during a hot spell and a hose fitting explosively separated from the hose due to the increased pressure from the hot water. We've used a pressure regulator at the spigot ever since and have not had any issues. Plus the particular regulator we use has an easier mechanism for tightening and loosening the connection to the spigot which alone is a good reason to use it.
Bob Martel
WBCCI# 5766
How to keep fresh water tank fresh and tasting good Driftin Di Fresh Water Systems 24 05-19-2017 05:45 PM
Use Black Water Tank as Aux Fresh Water Tank? DaytonaDan Plumbing - Systems & Fixtures 20 10-26-2016 08:53 AM
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 05:21 PM
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 09:51 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 11:50 AM
