Old 12-06-2010, 11:25 AM   #1
Fresh water tank: Level sensor wires
The 80 gallon Fresh water tank on my 1984 Classic Motorhome was MIA when I bought it, and replaced by a 15 gallon..
I have found a tank to replace it, but want the level system working too, and found this harness in the storage...
So I have following wires:
Black, Red, Green, Purple, and Orange with ring tabs.
Can anyone tell me how many sensor plugs I need(looks like 5) to get and how/where in the tank they need to go?
New tank is approx 14" tall.
Old 12-09-2010, 06:02 PM   #2
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
I will try to scan the page tomorrow, but here are the connections according to the manual.
Water Tank Common Sensor= Red
Full Level Sensor= Orange
3/4 Sensor = Green
1/2 Sensor = Yellow
1/4 Sensor = Blue
The Black tank common Sensor wire color is Brown
The Gray tank common Sensor wire color is Gray
They all share the level sensor wires.
Yes there are 5 sensors in each tank.
Hope this helps, Rob
Robfike is offline   Reply With Quote
Old 12-09-2010, 09:48 PM   #3
Awesome Rob!
You know, i feel silly now, as I have the service manual... and was looking for the wiring diagram for the tank... didnt think to look at the display panel diagram!
Doh!
So, to be clear..
I need a sensor very low in the tank.. and that is connected to red wire, and the rest in 1/4 tank height positions?
Old 12-10-2010, 08:39 AM   #4
Robfike's Avatar
Speedway , Indiana
Here are some pages from the Airstream manual. There are 5 probes per tank. The diagram is a little misleading. I will look at my fresh tank to see how the probes are arranged.
Rob
ID:	116806   Click image for larger version
Old 12-10-2010, 11:10 AM   #5
Robfike's Avatar
Speedway , Indiana
Well so much for the manual...typical.
Here is how it is really wired:
Purple to Full probe
Orange to 3/4 probe
Green to 1/2 probe
Red to 1/4 probe
Black to common probe
These wires come from the 6 way connector to the tank probes. The wires comming out of the wall going to the 6 way connector are different colors. They are together with the larger power and ground wires for the pump. They come out of the exterior wall basically below the filler tube.
The colors at the connector are as follows:
Blue with Yellow stripe = Purple
Orange/Yellow stripe = Orange
Green/Yellow stripe = Green
Red/Yellow stripe = Red
Black/Yellow stripe = Black
The following pictures should also help.
Rob
Name:	Airstream water wiring 001.jpg
ID:	116812   Click image for larger version
Name:	Airstream water wiring 002.jpg
Name:	Airstream water wiring 003.jpg
ID:	116814   Click image for larger version
Name:	Airstream water wiring 005.jpg
Old 12-10-2010, 02:51 PM   #6
Awesome Rob!
Oh, I looked everywhere for the connector when i was over there...
And then I looked at your photos, and looked at mine....
Good job it was not a snake!!!
And there it is... right next to the the pump! (Steve slaps himself!)
Old 12-18-2010, 11:12 PM   #7
Anyone know the best place to buy the sensor plugs?
Fresh Water Sensor Failure movin-in Fresh Water Systems 7 07-09-2010 09:58 PM
Fresh water level while travelling Mrs_RedSHED Fresh Water Systems 9 03-17-2008 11:02 AM
Water level Sensor removal/cleaning/replacement outofcontrol Fresh Water Systems 2 02-14-2008 02:39 PM
Level Sensor - Black water holding tank. mharrison@ie Waste Systems, Tanks & Totes 3 12-31-2007 06:09 PM
fresh water tank level and pumping Lumatic Fresh Water Systems 8 12-24-2007 05:51 PM
