Old 03-14-2021, 11:18 AM   #21
"Cloudsplitter"
Originally Posted by wscampo View Post
Clamb, Did you find your leak?
Is the FW tank completely full?
Ours leaked right from the gitgo, spent the first two seasons trying to trace it. Then I realized it was really only leaking when the tank was full.
It did continue to drip 'cuz the water pooled above the inspection panel.
Turned out it was the lower clamp on the fill neck vent tube.
I found the clamp hidden between the inner & outer skin, tightened and forgot about it, PITA to replace.
It only drips until the level drops below the clamp.🥴
Old 03-14-2021, 10:51 PM   #22
Road Geezer
Road Geezer's Avatar
2011 27' FB Flying Cloud
San Jose , California
Images: 40
Our leak turned out to be a bit more serious and required a new tank installation. Turns out the drain line leading to the exterior had cracked from too much flexing and bumps. Also where one of the pex lines attaches had actually cracked the connection fitting to the tank. WE opted for a new tank rather than a re-glue, etc. When replacing the tank, the repairman added loops to the pex lines for strain relief.
California has a lot going for it, but highways are banana republic quality, particularly the far right hand lanes. I think the bumps and jarring finally did the connections in.
Road Geezer
Respect Nature
Respect Science
Respect Each Other
Road Geezer is offline   Reply With Quote
Fresh Water Tank outlet leaking shermantic Plumbing - Systems & Fixtures 12 02-18-2009 08:43 PM
Leaking fresh water tank Yorkrus Fresh Water Systems 5 08-19-2007 12:44 AM
Leaking Fresh Water Tank gaylejoe Fresh Water Systems 9 09-30-2006 07:04 PM
Anyone fixed a leaking fresh water tank? JohnGalt48 Fresh Water Systems 2 06-28-2004 01:59 PM
HELP fresh water tank leaking wvabeer Fresh Water Systems 2 04-08-2003 11:10 AM
