Old 12-16-2006, 09:11 AM   #15
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Hurting
Right under the pantry.You know where it is.That hole is big enough for me to put my arm in but the water line going across it makes it tight.It took me a long time to figure out what the problem was.Just a lot of feeling around in the dark and remembering where everything is.My arm did hurt a little bit after doing everything cause it was so tight but it is fixed and now I am happy.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 12-16-2006, 12:51 PM   #16
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Oh yea, that's the spot I was thinking about. Fun times for sure....when my tank sensors were on the fritz, I'd grab a flash light and take a peek. I would do this from the access door under the curbside rear closet. One thing I realized after doing that a few times was that I wasn't as young as I once was.....
Water leak Raptorrider2001 1999 Safari 19 09-18-2005 08:21 PM
what holds black water tank in place tw64 1959-69 Tradewind 3 06-16-2004 11:05 PM
Water leak James Schmidt 1993 Excella 1000 11 02-02-2004 07:54 AM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
Leak in Water System Rich Palmieri Fresh Water Systems 6 06-27-2002 06:17 AM
