Old 08-26-2015, 10:37 PM   #1
clicker187's Avatar
2013 25' FB Flying Cloud
San Gabriel , California
Fresh water tank leak 2013 Flying Cloud
Our 2013 Flying Cloud fresh water tank is leaking. Any suggestions for repair? It looks like it came apart at the seam.
What about using....
J-B Weld 8272 MarineWeld Marine Epoxy - 2 oz. or
EternaBond tape. Calk or
Permatex Plastic Tank Repair Kit
Any other suggestions?
John Taggart
clicker187 is offline   Reply With Quote
Old 09-03-2015, 07:55 PM   #2
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
with a 2013, you're barely out of warranty. Have you asked AS to cover under warranty?
RAH is offline   Reply With Quote
Old 09-03-2015, 07:58 PM   #3
RAH
Cincinnati , Ohio
I am no expert, but before I tried to fix a FW tank split along the seam, I would see what the cost of a replacement tank was.
Good luck!
Old 09-03-2015, 08:00 PM   #4
RAH
Cincinnati , Ohio
and finally, I have not had good results with JB Weld Marine expoxy. it seemed too brittle once it dried.
Old 09-03-2015, 08:23 PM   #5
Seattle , USA
I attempted this once with JBWeld. It did not work. I fully prepped the surface; I sanded it, cleaned it with acetone and 91% alcohol, and used regular JBWeld (not the fast-curing version) and it didn't work at all. The plastic these tanks are made of seem to exude some sort of slipperiness that nothing will properly adhere to.
I'd replace the tank.
RareStream is offline   Reply With Quote
Old 09-03-2015, 08:39 PM   #6
1979 23' Safari
Wayland , New York
You'd be better off buying a replacement tank. Since it's recent it should be readily available. Short of plastic welding or some really expensive chemicals just about nothing sticks to the poly that the tanks are made of.
Old 09-04-2015, 08:19 AM   #7
2010 27' FB Classic
N/A , Texas
Here is a link to another thread discussing a leak. I used the epoxy mentioned and it solved my problem. It was a different problem but the epoxy (G Flex) mentioned worked for me and my tank is still leak free.
http://www.airforums.com/forums/f443...nk-120064.html
Old 12-08-2015, 08:17 AM   #8
Tallahassee , Florida
I have a 2013 25 FB Flying Cloud, last week I returned home from a camping trip and found the fresh water tank leaking. I crawled under the trailer and found no signs of damage. It look like water is dripping from the plastic tank cover between the axels. Anyone have advice on how to drop the cover and inspect the tank?
Omega Man is offline   Reply With Quote
Old 01-01-2016, 06:31 PM   #9
Snaken49's Avatar
2010 28' Flying Cloud
Fort Worth , Texas
Omega man,
There are many threads about FW tanks leaking from the water line attachment fitting to the tank.
According to others who dropped their tank themselves it appears the common cause is over tightening of fitting to the tank. This seems to be a manufacturing defect as the tanks themselves are designed for rugged industrial use in harsh environments.
http://www.ameri-kart.com/Home.aspx
Ameri-Kart supplies the tanks to Airstream out Indiana and they a very reputable firm.
The tanks are Low Density Poly Ethylene (LDPE). This kind of plastic can only be properly repaired by thermal welding that either use a special plastic hot glue gun, a high speed 15,000 RPM tool or a chemical weld that will melt bond the plastic together. see the video below
Check out this video on YouTube:
http://youtu.be/t-ixR6r9q6o
http://youtu.be/crmnzfDZDPU
Some folks have had success using other methods. But I doubt that repairs will last if the plastic is not welded together.
I have a 2010 28' Flying Cloud that just sprang a leak where the fresh water suction line attaches to the tank. So what you see in my post is a result of research in this forum and online.
Bottom line, you have a couple of choices; either have the tank repaired or replace it with a new through an Airstream dealer as Ameri-Kart will sell direct to the public.
Below is an excellent post showing a replacement of a 2010 28' Flying Cloud fresh water tank.
http://www.airforums.com/forums/f443...ng-114716.html
In my view this is a common enough problem that it could be defined as a manufacturing defect and certainly subject to warranty repair by Airstream.
Old Cobra AH-1G Pilot
WoundedWarriorsFamilySupport.Org
http://www.highfivetour.com/
Snaken49 is offline   Reply With Quote
Fresh water tank drain for a 2014 Airstream 27fb Flying Cloud Van1 2009-2015 Flying Cloud 9 08-03-2014 11:46 AM
2013 Flying Cloud 25' Water Leak Brent10 Plumbing - Systems & Fixtures 7 09-18-2013 06:54 PM
Fresh Water Tank Leak At Bottom of Tank From 1/8" Hole KJRitchie Fresh Water Systems 25 06-25-2013 08:25 AM
Can't fill fresh water tank 2009 20' Flying Cloud jkinglet Fresh Water Systems 6 06-07-2013 07:57 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
