Old 03-31-2014, 01:11 PM   #1
2011 23' FB Flying Cloud
Tallahassee , Florida
Fresh Water Tank Leak
It is unbelievable to me that Airstream allows their name to be associated with such inferior work. Now that i have vented.
I recently purchased a 2011 Flying Cloud 23FB. I've never used it. Didn't know it had a leak until we got it home and filled with water. it drips once about every second. I've checked all of the external connections including the drain plug underneath. We cannot visibly determine where the leak is. So I assume the tank cover needs to be removed before further inspection. My question is this: Should I take it to a dealer and pay the $700 that it will take to get this repaired or attempt to do it myself. Anyone with experience please include your suggestions or recommendations. Thank you!
1Cruzin is offline   Reply With Quote
Old 03-31-2014, 02:17 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Not that they're perfect but why blame Airstream for a 3 year old trailer you just bought that has a leak.
Anyway, welcome to the fellowship. Are you sure the leak is coming from the water tank and not from somewhere else nearby? Could the tank have been filled with too much pressure that is forcing a leak at a fitting, drain it down some and see if it leaks.
Doug and Cheryl
Old 03-31-2014, 02:28 PM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Where is the water dripping onto the ground from? That knowledge would help us give you advice as to how to trace it. If you can't see it, lay on the ground with your head in the puddle and look up. You will find out in 1 minute or less.
Ken
Old 03-31-2014, 02:36 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Step back for a bit.
It is too early to tell. Drain the tank and wait of the drip to stop. This may take some time depending if the insulation, other than at the tank got wet. The tank is encased in Styrofoam and will not hold water. Once thing have settled down slowly fill the tank through the line that feeds the pump. Disconnect at the pump and make a connection to a garden hose. By back weeding the tank this way you are eliminating the fill tube, which may be loose at the tank connection. If it leaks this way you know it is the tank.
Once you determine if it is the tank and not the fill tube you can decide what to do.
If it is the tank and you have the ability to drop the belly pan do so and look around. An ABS tank can be fiber-glassed. Not sure about a poly tank.
$700.00 without them even knowing waht the problem is sounds like a Profit Center to me
2004 Excursion 4x4
Old 03-31-2014, 02:48 PM   #5
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the forums! Have a good look around here and you'll find lot's of Airstream gripes that probably make Wally spin in his grave. Fortunately, there is this community of die-hard enthusiasts who will offer support, advice, and maybe even a little expertise.
For your water leak, the good news is that there are very few "penetrations" in the tank that are supposed to be there--the fill port, the breather tube, the pump connection, and maybe, possible, a drain. So if the dripping is occurring at a point opposite of where the above connections connect, you may have an unintended penetration, so to speak (ie., tank split due to freezing, screw unintentionally run into the tank, etc.). One thing you might try is to drain the tank, wait for all dripping to cease, and then connect the trailer to the "city water." Your water tank should be isolated from the city water, so if you see your leak start up again, then you will know that it is not the tank that is leaking, its some plumbing line.
good luck!
Old 03-31-2014, 07:07 PM   #6
Thanks Doug...Yes, pretty sure that the leak is from the tank or one of the fittings that goes into the tank. At this point, it doesn't matter. I'm trying to decide whether or not this job is for a professional. I am capable of making repairs but don't want to open up a can of worms just to save a few bucks?
Old 03-31-2014, 07:09 PM   #7
The leak is on the driver side and is coming out where the metal plate covers the larger drain plug. I remove the plate, that is how I know.
Old 03-31-2014, 07:11 PM   #8
That is a good idea. I will do that tomorrow.
Old 03-31-2014, 07:15 PM   #9
All good advice. I appreciate your input among a few others. I called AS and got a Fresh Water system diagram that may help. Thank you!
Old 04-02-2014, 10:18 AM   #10
Problem Found with Fresh Water Tank
We finally located the source of the leak. It was at the tank fitting for the Water Pump at bottom side of the tank. There are two solutions. First is to use a product like Marine Tex which is a two part marine epoxy like product that dries hard. Second is to remove the entire tank and of course it is the least desirable. I've elected to try and make the repair. Not sure the attached photo downloaded but if it did, check out the fitting. This was cause by sloppy installation at the Airstream factory. What else?Click image for larger version
Old 04-02-2014, 10:38 AM   #11
Ag&Au's Avatar
We finally located the source of the leak. It was at the tank fitting for the Water Pump at bottom side of the tank. There are two solutions. First is to use a product like Marine Tex which is a two part marine epoxy like product that dries hard. Second is to remove the entire tank and of course it is the least desirable. I've elected to try and make the repair. Not sure the attached photo downloaded but if it did, check out the fitting. This was cause by sloppy installation at the Airstream factory. What else?Attachment 208822
Did you have to drop the tank cover in order to get the access shown in the picture?
The problems of sloppy assembly are not unique to Airstream. It is very common in the RV industry. Prior to my Airstream, I bought a brand new Casita, followed several years later, by a brand new Bigfoot. Both required things that had been hastily and sloppily be put right. Both had cross threaded and or improperly sealed plumbing fittings that needed repair.
Ken
Old 04-02-2014, 10:40 AM   #12
Belegedhel's Avatar
Houston , Texas
Huh...it looks like the "spun-on" fitting has separated from the tank. If so, you will be trying to glue HDPE to HDPE, and not very many things stick to HDPE. Regardless, its worth a try--easier than dropping pulling the tank. The other thing to check, is whether that line to the water pump is putting a bind on the tank fitting. You might also want to put a longer hose in that section so that it has a little slack and isn't pulling on the fitting.
Old 04-02-2014, 11:58 AM   #13
Zia
2011 23' FB International
2007 20' Safari
Irvine , California
Smile Fresh water tank leak
I have 2011 23 FB International serenity and had the same fresh water leakage issue. Fortunately it was under warranty. The dealer told me that leak was at the connection of the drain pipe. They removed the tank send it to place where they re-spun the fitting (this was there wording). They installed the tank with new insulation. We love our unit already have over 10,000 miles and planning to go to Alaska this summer. Good luck
Zia is offline   Reply With Quote
Old 04-03-2014, 05:05 AM   #14
Thank ken, I did NOT drop the tank. I gained access by cutting away a necessary portion of the galvanized cover pan from the bottom. It was somewhat difficult but do-able. I'll find out this morning if my efforts were successful. I'll refill the tank and then check for leaks.
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 03:45 AM
Fresh Water Tank Leak At Bottom of Tank From 1/8" Hole KJRitchie Fresh Water Systems 25 06-25-2013 08:25 AM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
Fresh water tank leak Flex Fresh Water Systems 3 09-30-2004 04:25 AM
Major fresh water tank leak! JohnGalt48 Fresh Water Systems 2 05-17-2004 05:50 PM
