Old 04-26-2006, 06:32 PM   #1
Portsmouth , Rhode Island
Fresh Water Tank is Sagging
Hi,
My 2005 Safari 25' has a 3-4" sag in the middle of the fresh water tank, however, the gray water tank is perfectly flat on the bottom. Is this sagging condition normal?
Name:	Airstream Fresh Water Tank Issue 007b.jpg
Hunter_1 is offline   Reply With Quote
Old 04-26-2006, 07:32 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Some distortion is normal, and expected, just from the weight of the water. Yours seems a little more than most, but not too bad. Just put it on a list of things for your dealer to look at next time it is in for service. It DOES have water in it at the time the photo was taken?
Old 04-26-2006, 07:58 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
This looks just like the tanks on my 2006. Flat metal straps like that would not function as a beam to support sag in the middle. The black plastic probably encases a layer of insulation and the tank is some depth up inside this structure. I know that the trailer did start with the axle an inch or so about the tanks... I'm not about to tear this new of a trailer apart, but it sure makes you wonder what tank supports might be hidden out of sight. They might just be alright. Then the black plastic might just be sagging from heat/weight.
Do you store it with any water in the tank or do you camp parked for long periods?
5 meter Langford Nahanni
Old 04-26-2006, 08:57 PM   #4
tpi
Trabuco Canyon , California
My '05 25' Safari definitely has a sag in the fresh tank, looks similar to the pic you posted.
I usually drive with it full to dry camping destination.
tpi is offline   Reply With Quote
Old 04-27-2006, 05:55 AM   #5
Thanks for the feedback.
The tank had 10-15 gallons of water in it at the time the photo was taken. During the camping season, the fresh water tank is generally topped off each day.
Old 04-27-2006, 09:32 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Yes, mine looks like that too, when I have water in it. It was a shock the first time I filled it, but it is normal, in my opinion.
congrats on your new unit!
Pat
pmclemore is offline   Reply With Quote
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 07:11 AM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 07:09 AM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 09:52 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 05:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 03:59 PM
