Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 05-01-2009, 06:44 AM   #1
ellenwall
Profile:  2007 27' Safari FB SE
Shawano , Wisconsin
Fresh water tank in '07 won't drain - Help!
We have a 2007 Safari, and need to drain the fresh water tank as part of our spring ritual - the valve turns, but will not drain.
ellenwall is offline   Reply With Quote
Old 05-01-2009, 07:49 AM   #2
Profile:  1966 22' Safari
Keller , Texas
Dirt Daubers
When our '66 Safari did the same thing, we found the drain line under the trailer completely stopped up with dirt dauber nests (unknown age). The trailer had been sitting for 6 years since the PO had used it.
At least it's a cheap thing to consider first, if you live in, or have been to dirt dauber country. Those darn wasps will build in any tubular structure, since it saves them time in building tubes out of mud.
Old 05-05-2009, 06:23 PM   #3
ellenwall
Shawano , Wisconsin
Thanks ... we'll check it out.
drain valve on fresh water tank: 79Argosy6.0 campman All Argosy Trailers 7 01-26-2009 06:59 PM
Is there a drain for my Fresh water Tank!! Mrcrowley Fresh Water Systems 1 12-02-2008 04:44 AM
Fresh Water Tank Drain NEW94 Fresh Water Systems 5 11-04-2007 08:58 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
Really need a drain on the fresh water holding tank?? SmokelessJoe Fresh Water Systems 16 06-17-2007 07:50 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
