Old 09-09-2008, 09:27 PM   #1
1965 22' Safari
memphis , Tennessee
Fresh Water Tank Help
hi, here are 2 pics of the original water tank in '65 safari. i believe that the left side of the tank is the outlet which t's off to a drain below. can someone explain how the right side of the tank works and since i'm replacing all of it, what would be the ideal way to do it. i'm guessing the right side is venting somehow, but i don't quite understand it.
thx,
bob
ID:	67162   Click image for larger version
rburditt is offline   Reply With Quote
Old 09-09-2008, 10:42 PM   #2
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
The r/side is your sight glass
Diesel1 is offline   Reply With Quote
Old 09-09-2008, 11:35 PM   #3
thx,
bob
The venting is in the filler neck cap.
We have the tanks and the filler neck caps.
Old 09-10-2008, 10:52 AM   #4
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
Your tank looks similar to the one I replaced in my '64. I picked up a new plastic one for $60.00 from a place in Elkhart, IN. If you are interested I can send along the contact info.
Later - Derek
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
Old 09-10-2008, 12:15 PM   #5
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Andy has the originals but mine was a 30 gal and I moved up to a 39 gal.... Most new ones do not come with no holes in them..(unless the original ones.) Because of this you will need to find someone who can weld plastic to put in your fill and out holes...or order an original..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-10-2008, 12:16 PM   #6
purman's Avatar
1968 28' Ambassador
Also I am putting probes in so I can keep track of my water level... You may want to think about this instead of the old sight glass method....
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-10-2008, 01:35 PM   #7
1965 22' Safari
memphis , Tennessee
2 more questions...how do the probes work and also, i think i understand the sight glass but what is the copper runninig thru the bottom of the floor? i've already torn it out...i should have paid more attention to it...i dont think it connected to anything however???
Old 09-10-2008, 02:03 PM   #8
purman's Avatar
1968 28' Ambassador
The copper going through the floor was a vent for the sight glass so it would work... The probes, Well there are two different types from what i understand..
My original one went in the top of the tank and measured empty or 1/2 full...... The new ones are little nuts that drill in the side of your tank.. E .. 1/3 .. 2/3.. full So you need four of them and they connect to a mess of wires that then go to a sensor board you buy to show you how full the tank is... I am going to put in a grey tank so I will also hook this up and the black tank.... Any RV dealer will help you with theses...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-10-2008, 08:50 PM   #9
1965 22' Safari
memphis , Tennessee
If my tank is vented thru the filler neck and i use probes instead of a sight glass then i'm guessing the only holes i'll need (besides the filler and probes) in the tank would be an outlet & drain?
Old 09-10-2008, 10:03 PM   #10
Correct.
Probes can easily be added to the tank, but you will have to install a gauge system. Generic gauge systems are available.
Our tanks have all the necessary holes, except for the probes.
Old 09-10-2008, 10:20 PM   #11
purman's Avatar
1968 28' Ambassador
And if your fresh water tank is like mine.. It is gross.. Black stuff in it... The truth is my Black tank looks cleaner inside than my Fresh tank...
The other reason I didn't go with the original tank is, I'm gonna use my old fresh tank as a grey tank.. Its different than yours.. Mine is only 6 inches high 2 ft wide and 50 some inches long so it will fit right under the frame by the axels...( I hope)
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-11-2008, 08:02 AM   #12
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
The one I purchased, not from Andy cuz I like to save money, was a sealed translucent plastic tank. It came with fittings that had rubber gaskets on them, once you drill or cut the correct size holes you insert the fitting and tighten it, this makes the rubber gasket expand and hold to the tank. With a sealed tank you can modify the installation to your liking. I did check the website I bought mine and for a 29 gallon +/- 12" x 12" x 48" tank the price is $70.00 with three small fittings and one large fitting.
D
Old 09-11-2008, 08:44 AM   #13
purman's Avatar
1968 28' Ambassador
Mine new tank is 9" x 22" x54" It can't be higher than 9" because it goes under the front couch.. mine was a lot more $240 but i didn't pay shipping... and its a 39 gal... I will have to fork out another $50 for the plastic welds, but the fittings will go where i want them, and I don't have to worry about rubber gaskets leaking... Although the rubber should be fine... The probes work with the expanding rubber gaskets... So I will have some...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-11-2008, 08:45 AM   #14
D
Rubber, being rubber, eventually will harden and shrink.
Then the liquid leaks appear, and hopefully caught in time so that resultant damage is kept to a minimum.
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
Fresh Water Tank ??'s kevino Fresh Water Systems 28 08-26-2007 06:25 PM
Fresh water Tank Devoman Fresh Water Systems 16 08-08-2006 03:55 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
