Old 05-02-2014, 10:28 AM   #1
Shads Shack's Avatar
2005 22' International CCD
Pittsburgh , Pennsylvania
Fresh Water Tank Gauge
2005, 22', Intn'tl CCD. 30 gallon fresh water tank. CATCON Micropulse monitor.
I cannot get proper monitor readout on fresh water tank. When filled, but before routing water through hot water tank, monitor reads full. After routing water through 6 gallon heater monitor reads empty. Fill additional 6 gals into fresh water tank and monitor reads full. It seems that losing 6 gals drops monitor reading from full to empty. Sounds like a calibration problem. Catcon manuals are unavailable and I haven't found an Airstream calibration method. Black and gray tank monitor readouts seem OK. Help please.
Shads Shack is offline   Reply With Quote
Old 05-02-2014, 11:19 AM   #2
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
This should help:
http://campadk.com/airstream/MicroPu...itorManual.pdf
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 05-02-2014, 01:26 PM   #3
insearchoffun
exallen's Avatar
2012 30' Classic
Box Elder , South Dakota
Calibrating helped, but note that the 5 labels (Cal Complete, Ready for full, Ready for empty, select tank, and Diagnostics) shown on the bottom of the Micropulse in the calibration guide are not really there. I think it is a stick on label that gets peeled off when first installed. So have your guide handed while you're doing the calibration. Might as well calibrate the gray and black tanks while you're at it.
insearchoffun
exallen is offline   Reply With Quote
Old 05-04-2014, 05:43 AM   #4
Thanks all. Have downloaded the information and will try it out. I'll report back my results.
Fresh Water Tank Leak At Bottom of Tank From 1/8" Hole KJRitchie Fresh Water Systems 25 06-25-2013 08:25 AM
Black/grey Water Tank Gauge is.chowa Land Yacht/Legacy Motorhomes 4 09-24-2011 11:12 AM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-01-2011 11:51 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
Water tank gauge FreshAir Fresh Water Systems 22 07-12-2008 11:24 AM
