Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 08-02-2010, 06:04 PM   #1
1977 27' Overlander
St. Charles , Missouri
Fresh water tank flush
Hi there.
To make a long story short I dropped the fresh water tank out of my 77 Overlander, it's plastic by the way. And it's got a bit of sediment and I'm wondering whats the best way to flush it out. Any thoughts or suggestions would be appreciated.
Greg
spindle is offline   Reply With Quote
Old 08-02-2010, 07:49 PM   #2
r carl's Avatar
Lin , Ne
Position it with the opening down, use sawhorses or whatever. Now use hose with a small sprayer that you twist or use a powerwasher, your sediment will run out as you spray the inside.
Old 08-02-2010, 07:53 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I wish ours was just sediment inside. It's a "lovely green color". I'm going to try to bleach and then flush. Let us know how your's goes!
Kay
Black Water Tank Flush neil ervin Waste Systems, Tanks & Totes 13 07-26-2010 02:37 PM
Black Water Tank Flush Problem Bilo Hak Waste Systems, Tanks & Totes 4 02-15-2009 05:21 PM
Black Water tank flush leaks bfwoz Waste Systems, Tanks & Totes 2 07-06-2004 04:06 AM
No Fuss Flush and Fresh Water Hose? docbluedevil Waste Systems, Tanks & Totes 3 04-07-2004 10:07 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
