Old 10-16-2015, 12:40 PM   #15
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Fixed? Fingers Crossed!
Poking around I found a likely spot for the leak, under the tank intake flange. I first tried spraying the area with Home Depot Leak Stop. Didn't work. I then cut a window in the belly pan which supports the tank. I was then able to see a 4" crack extending in both directions of the intake flange. I used some JB Weld Water Weld which claims to stick to "almost anything". We'll see.
While underneath I nicked the copper propane line. Decided it was a good time to put in a T and install a Humphrey propane light while I was at it.
Old 10-16-2015, 02:50 PM   #16
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
JB Weld has a talent for self promotion. If it sticks to that polyethylene tank, I'll eat my blue beret.
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
Replacement fresh water tank needed zamboni Fresh Water Systems 16 04-20-2007 09:36 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
Replacement Fresh Water Tank ON SAFARI Fresh Water Systems 6 07-13-2004 09:54 PM
