Old 03-02-2007, 10:58 AM   #1
Gold Rivet Member
tgregory13's Avatar
Fuquay , North Carolina
Fresh Water Tank Fitting Sizes
I need some help here... adding a fresh water tank to the 63 overlander, I know where i want my vent, fill, and pump connections on the tank i just dont know what size i should use for each. is there a standard for this??
have a good 1...
Todd
(why do i have to press 1 for english??)
tgregory13 is offline   Reply With Quote
Old 03-02-2007, 12:54 PM   #2
Images: 59
I used 1.5" for the vent and fill connections, and 1/2" for the pump and drain connections.
Old 03-02-2007, 01:17 PM   #3
Gold Rivet Member
tgregory13's Avatar
mark... did you cut those in yourself or did you order the tank with them pre-installed.... I dont know why but i have wore myself out with the placement and size of these fittings... i think i'm to the point were i'm just going to order it with no fittings installed that way if i need to make a change i can without haveing to plug one of the "factory" installed fittings...
have a good 1...
Todd
Old 03-02-2007, 02:15 PM   #4
Images: 59
Todd,
I ordered my tank with the fittings installed. I placed the two vent openings in the upper inboard corners.
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Safari owners Jerry Sulkin 1969 - 1973 Safari 30 02-20-2006 07:07 PM
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
Sanatizing the Water Tank? 68 Suburban Fresh Water Systems 3 10-13-2002 12:22 PM
