Old 11-11-2006, 07:54 PM   #1
Dano57's Avatar
1979 31' Excella 500
Edmond , Oklahoma
Fresh Water Tank Filler
I have a 79 Excella 500 with a street side port to fill the fresh water tank. It is labeled with the Thetford brand name. The door is aluminum but the backside piece I believe is plastic. The filler hose and vent line attach to this back piece. The vent line has broken off from the assembly. Do any of you know if this part is available and/or where I try to find one?
Dan
Dano57 is offline   Reply With Quote
Old 11-11-2006, 11:39 PM   #2
ayresdream's Avatar
1971 29' Ambassador
Merritt , British Columbia
You can check with an Airstream parts supplier, like Inland RV. I'm not sure of the exact part, but you can sometimes find the parts in an RV store like Camping World.
Can you post a picture of the part?
ayresdream is offline   Reply With Quote
Old 11-12-2006, 11:28 AM   #3
Dano57's Avatar
Edmond , Oklahoma
ayresdream,
I have looked all over the net and can't come close to one and I did look at Inland's sight too. I'll get a picture and post it, that is a great idea.
Dan
Old 11-12-2006, 12:14 PM   #4
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Originally Posted by Dano57
ayresdream,
Dan
Dan,
Andy at Inland has a lot more parts than he puts on his website. Call his toll free # and ask. You have nothing to lose but a few minutes. Good luck.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 11-19-2006, 08:00 PM   #5
Dano57's Avatar
Edmond , Oklahoma
Hi All,
I finally took some pictures of the potable water inlet. The red arrow points to the area that is deteriorating. So, any suggestions on where to get one of these inlets?
Dan
ID:	28830   Click image for larger version
Under Renovation,
As yet to be towed!
Old 11-19-2006, 08:20 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Dan!
My Argosy had a very similar fresh water fill that also posed problems. The interior plastic components degraded and a leak was the result. Ace Fogdall RV investigated the availability of a replacement and nothing remotely similar was available, and the only solution was to install one of the more modern alternatives. Several Argosy owners have had reasonable luck utilizing plastic/fiberglass repair kits to repair the interor portion of the device.
Good luck with the solution to your fresh water fill problem!
Kevin
Kevin D. Allen
AIR #827
Old 11-19-2006, 08:21 PM   #7
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
That looks like the same one that is on my '73. Let me look thru the shop manual and see if I can find the original part number. Back in a few.
On edit: Yep, here you go. It's called a "Spout, Water Fill" The original part number is 04210. Many of the original part numbers have changed to a more modern system in the Airstream inventory. Check with a reputable Airstream dealer and they can get ya one if they are still avilable. Yoy might also try Colaws RV, they have several wrecks on the lot. DO a search on the forum to get their number & webpage.
www.nesa.org
Air No. 6427
Old 11-19-2006, 08:32 PM   #8
Dano57's Avatar
Edmond , Oklahoma
Jim,
Outstanding info, thanks.
Dan
Under Renovation,
As yet to be towed!
Old 11-19-2006, 08:33 PM   #9
Got gandkids?
Here's the Colaw website: http://www.colawrvsalvage.com/
www.nesa.org
Air No. 6427
Old 11-19-2006, 09:05 PM   #10
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
What a coincidence! I just finished piecing mine back together. Mine wasn't quite as bad as yours but it was pretty cracked up by the time I removed it from the Sovereign.
Of course, my kitchen console is removed so it was no big deal to cut away some inner skin to get to it. (I had to drill the factory buck rivets out from the outside.)
Anyway, it must be removed from the inside and probably won't come out in one piece. (A putty knife between the plastic and the backside of the outer skin was used.)
I pieced it together with some marine epoxy and then used some Evercoat stranded fiberglass body filler (the blue/green stuff available at fine auto/paint supply stores) on the entire back of it to reinforce it. I too had some missing pieces but the filler hopefully will "fill in" nicely. It sits next to me on the counter, curing as I type.
Good luck finding another one. I didn't see anything on the web, but if you do find it, let us know!
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 11-19-2006, 09:19 PM   #11
Dano57's Avatar
Edmond , Oklahoma
Ron,
Mine is on the street side and is under the inner fender skirt. I had to cut a small access hole in the skirt to get to it to try to reattach the hoses. If I have difficulty removing it I'll probably have to cut a bigger hole. I think I might as well go after it and remove it and do as you did. Oh well, let the fun begin.
Dan
Under Renovation,
As yet to be towed!
Old 11-20-2006, 06:18 PM   #12
Dano57's Avatar
Edmond , Oklahoma
Well folks, I have done some more research, called Thetford and they didn't have a clue what the water inlet is or if they ever made one. They sent me to a distributer that was in the know, well he didn't have a clue either. Off to the Airstream dealer and he said that he has not known of any being available for a long time. He suggest modifying the trailer with the modern version, he showed me one on a 2002 model. Not as classy looking but would work.
I think I am going to remove mine and see if it can be repaired with fiberglass, if not I'll replace with the new version. It appears that I'll have to enlarge the opening in the trailer to do it. If I go that way I'll post my results as it seems more than one of us has this problem.
Dan
Under Renovation,
As yet to be towed!
Old 11-21-2006, 06:36 AM   #13
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
Dan,
Carefully drill out the rivets from the outside and then very carefully slide a very thin putty knife between the skin and the plastic housing. It might be best to try to cut away as much vulkem on the inside as possible, to reduce the resistance to removal. Mine was actually affixed to the inside of the outer skin with double-sided tape, surrounded and sealed with vulkem. It is no wonder it came out in about 8-10 pieces.
I carefully saved all the pieces and patiently reassembled the puzzle using 2-part marine epoxy (sets in 50 minutes, gray in color). After complete assembly, I put a layer of short strand fiber reinforced body filler on the back and it seems to work fine.
The only part that shows from the outside is the door and the little bit of exposed housing.
I'll try to post some pics of the finished product.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 11-21-2006, 10:23 AM   #14
Dano57's Avatar
Edmond , Oklahoma
Ron,
Thanks for the heads up. Looks to be quite a job for a small part! I am sure that it may be the same on mine as the part looks to be thin and crumbling already.
Dan
Under Renovation,
As yet to be towed!
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Fresh water tank cleaning Krazykraut Airstream Motorhome Forums 7 01-16-2003 09:29 PM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
