Old 09-03-2015, 02:11 PM   #1
1989 29' Excella
Hudson , Ohio
fresh water tank fill hose leak
Looking for a simple fix. I have a crack in the flexible fill hose that connects to the fresh water tank. The leak is just above the metal strap that holds the hose to the tank. I can't disconnect the hose because the strap is barely accessible and the screw that tightens the strap is rusted and pointing in the wrong direction. I'm hoping for an easy fix --- maybe a waterproof tape, maybe cutting out the bad section. Any suggestions will be greatly appreciated.
Thanks Pat G
Pat G is offline   Reply With Quote
Old 09-03-2015, 05:32 PM   #2
1979 23' Safari
Wayland , New York
The screw posts on the hose clamps are usually also bolt shaped. You should be able to get a ratchet with socket on it and loosen it a little at a time. Push the hose down so it's under the clamp or try trimming a little bit and putting back on and retighten the hose clamp.
Old 09-03-2015, 05:49 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Cut the old rusty hose clamp off with a Dremel and cutting disk. Don't try to repair an old leaking hose. Replace the hose and use new stainless hose clamps.
Do it right and be done with it.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Can water heater fill from fresh water tank? phann Water Heaters, Filters & Pumps 14 02-04-2018 02:10 PM
Noobie - how to fill fresh water tank? Bohemian Fresh Water Systems 26 10-18-2016 02:51 PM
Fresh water tank fill hose VAtom Fresh Water Systems 11 04-10-2015 04:20 PM
LEAK: Fresh Water Fill judithd Fresh Water Systems 11 02-25-2015 02:36 PM
fresh water fill hose/adapter wmarsha Fresh Water Systems 7 08-12-2012 01:34 PM
