I Have A 94 Land Yacht Motorhome & Cannot Figure Out How To Drain Fresh Water. Owners Manual & Other Sources Have Proven Non Productive Any Help Would Be Appreciated.
My 2000 with queen bed has the pump and drain valves for the water tank and hot and cold water lines behind a panel at the foot of the bed. Don't know if yours is similar.
I have the same problem; how does one drain the fresh water tank? On the street-side, below the fill door/receptacle, underneath between the tandem wheels are two pet-cocks......are these THE only drain?
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
I have found that even with the drain open on my litle 25gal tank, it takes a huge amount of time as the water seems to just piddle out of the tank....and it IS vented!
My solution is to open your gray tank valve, open a faucet or 2 and turn on your water pump. If you have a high flow pump (mine is 4gpm) you will empty your tank in no time at all!
Try it......you'll LIKE it!
lewster
