Old 10-29-2007, 12:32 PM   #1
94 LAND YACHT
1994 31' Legacy 30
FOLSOM , Louisiana
Fresh Water Tank Drain
I Have A 94 Land Yacht Motorhome & Cannot Figure Out How To Drain Fresh Water. Owners Manual & Other Sources Have Proven Non Productive Any Help Would Be Appreciated.
NEW94 is offline   Reply With Quote
Old 10-29-2007, 04:07 PM   #2
jimmickle's Avatar
2000 31' Land Yacht
My 2000 with queen bed has the pump and drain valves for the water tank and hot and cold water lines behind a panel at the foot of the bed. Don't know if yours is similar.
jimmickle is offline   Reply With Quote
Old 10-29-2007, 05:16 PM   #3
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
I have the same problem; how does one drain the fresh water tank? On the street-side, below the fill door/receptacle, underneath between the tandem wheels are two pet-cocks......are these THE only drain?
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 10-29-2007, 06:24 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
I have found that even with the drain open on my litle 25gal tank, it takes a huge amount of time as the water seems to just piddle out of the tank....and it IS vented!
My solution is to open your gray tank valve, open a faucet or 2 and turn on your water pump. If you have a high flow pump (mine is 4gpm) you will empty your tank in no time at all!
Try it......you'll LIKE it!
Old 11-04-2007, 08:21 PM   #5
2001 35' Land Yacht XL w/2 slides
San Jose , California
Is there any way(and not offending anybody)to drain JUST the freshwater tank and not be connected to a campground sewage drain?
bearmoi is offline   Reply With Quote
Old 11-04-2007, 08:58 PM   #6
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
One my 06 Classic there is a drain petcock between the two axles on the curb side.
Michelle TAC MT-0
Sarah, Snowball
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
fresh water drain '81 Excella II ole81 Fresh Water Systems 8 09-25-2007 10:41 AM
Really need a drain on the fresh water holding tank?? SmokelessJoe Fresh Water Systems 16 06-17-2007 07:50 AM
Fresh water drain ? TexasStars Fresh Water Systems 6 10-29-2003 12:09 PM
Fresh water drain Happycampers Fresh Water Systems 0 07-21-2003 04:54 PM
