Old 05-04-2007, 04:58 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Fresh water tank desgin
I'm getting ready to order a fresh water tank. I also need a fresh water fill to install in the side of the trailer. I'm looking for some input there. That will dictate the size for the fill opening in the tank.
I also need a vent that will go out the trailer side as well. Any ideas?
So the tank would have a 1/2" output at the bottom to feed my pex line to the water pump. I plan to tee off the tank output to a drain valve that goes to the pump.
So, one fill input probably 1" fitting, 1 vent input at the top 1/2", and one output on the bottom 1/2". If I can't find a vent connection for the side of the trailer, can I vent out the bottom of the trailer?
This is an above floor tank under the front window. Is 25 gallons enough?
-Tim
theVAP - Airstream Podcast
Old 05-04-2007, 05:03 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
We have a 15 gallon tank, and would like another 10. I would call 25 a miminum, can you get and fit a 30 there?
Old 05-04-2007, 05:18 PM   #3
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
A vent to the floor will need some sort of flapper valve to keep bugs, etc from working their way into your tank.
Ideally the vent would exit at the same place as the fill.
ID:	36852   Click image for larger version
Fyrzowt is offline   Reply With Quote
Old 05-04-2007, 05:20 PM   #4
Fyrzowt's Avatar
2000 25' Safari
Images: 8
Outside view
Old 05-04-2007, 05:31 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My setup is just like Fyrzowt's posts. My 75 TW has a 45 Gallon tank which is plenty. I wish my holding tanks could hold that much as well.
Richard
Old 05-04-2007, 05:36 PM   #6
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
My grey tank is about 27 gallons and the black is about 20.
What I really need are some leads on some nice water fill and vents that I can add.
-Tim
Old 05-04-2007, 05:50 PM   #7
Images: 59
Tim,
I was able to fit a 28gal tank behind the gaucho. I used 1 1/2" vent & fill connections at both ends of the tank. Haven't decided yet which will be the inlet and which will be the vent. I will reuse the original inlet, and on the opposite side there was a police radio antenna which I will convert into a vent.
Be cautious if you run the vent through the floor. Besides the problem with spiders, you need to avoid creating a siphon.
In addition to the pump outlet, I added a separate 1/2" drain in the bottom of the tank so I can drain it completely dry in the winter. I also pitched the tank 3/4" toward the outlet end.
Name:	Water Tank002.jpg
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 10:08 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
