Old 08-09-2015, 10:36 AM   #1
Creggster
casandel's Avatar
2013 28' International
Livingston , Texas
Fresh water tank confusion
I have a 2013 international serenity. I have never filled the fresh water tank. When I finally decided to treat it in connection with going full time I discovered it was full. Is it possible that it is filling itself when I'm plugged in to park water or is there a valve that needs to be closed?
casandel is offline   Reply With Quote
Old 08-09-2015, 10:42 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you bought the trailer new, then it's entirely possible that even though you never filled the fresh tank, the dealer did, in preparation for your walk-through, and you've been carrying a tank of fresh water for a couple of years.
Easy way to find outů Drain the fresh tank. Hook up to municipal water. Then see if the fresh tank fills itself.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-09-2015, 10:57 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
First try what Protagonist suggest above. If your empty fresh water tanks fills when you are hooked up to city water, then you have a defective check valve. Not sure if the check valve is separate from the pump or is integrated with it but it would need to be serviced or replaced. A defective check valve is not uncommon.
Bob Martel
WBCCI# 5766
Old 08-09-2015, 11:15 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Make sure to disinfect throughly. After two years I bet there are some nasty beasties growing in the tank and associated water lines.
MICHAEL
Old 08-09-2015, 11:54 AM   #5
Mission , Texas
Curious ... if the fresh water tank were filling when hooked up to city water supply inlet, how does it know when to stop filling?
If the check valve at the pump were defective allowing water to enter the tank, wouldn't the water eventually start pouring out of the fresh water tank fill port? (unless this is has a good cap)
nrgtrakr is offline   Reply With Quote
Old 08-11-2015, 10:25 AM   #6
AIR #6370
hmsteader's Avatar
2001 27' Safari
Bella Vista , Arkansas
Are you using an external water pressure regulator when connected to city water?
I had one occurrence that I did not use an external pressure regulator and I'm guessing that the city water pressure was too high late at night that the water back-filled into the fresh water tank. Fortunately the fresh water tank overflow worked properly. I awoke about 2am hearing the check valve cycling at a high rate.
I wouldn't have expected this to happen but it did in this one instance.
hmsteader is offline   Reply With Quote
Old 08-11-2015, 10:09 PM   #7
2008 25' International
crescent city , California
How to put bleach in fresh water tank? and then how to drain it instead of draining it into grey water tank? think it is a 30 gallon tank so almost 4 oz of bleach -is that correct?
Have a 2008 25ft front bedroom
thanks,
Catherine
surfsup is offline   Reply With Quote
Old 08-12-2015, 05:04 AM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question Use it or lose it....
"I have never filled the fresh water tank"......well at least you didn't have a noisy water pump.
That must have been a very thorough dealer orientation....
FWIW.....it should NOT fill by itself from the city supply line.
"How to put bleach in fresh water tank? and then how to drain it instead of draining it into grey water tank? think it is a 30 gallon tank so almost 4 oz of bleach -is that correct?
Have a 2008 25ft front bedroom"
thanks,
Catherine
Catherine,
4oz is fine, bleach in the grey is not a problem, fact is, it will probably help.
Fill thru the curb side inlet, the door should look something like this.....there may be a sticker on it saying "potable water only".
The fresh water tank drain should be underneath the trailer, curb side, between the axles.
The white plastic valve in the photo......
Also....pump the bleach solution thru the entire system, before flushing it clear. (I let it sit for at least 12hrs)
Old 08-12-2015, 05:25 AM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, is it really full, or does the gauge say it's full; Never trust the gauge!
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-03-2015, 08:09 PM   #10
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
yes
Yes. It is kind of odd to be hooked up to city water, and have a leak on the other side of your trailer from the fresh water overflow.
We had this in our first year when the trailer was new. I put in a new water pump way before I thought I would have to!
RAH is offline   Reply With Quote
Old 09-03-2015, 08:19 PM   #11
1979 23' Safari
Wayland , New York
Instead of putting in a new pump you can put a valve in on the pump outlet, close it when you're not using the pump. Stops potential back leakage through the pump. Also most pumps have replaceable diaphragms in them which are fairly cheap compared to replacing the pump.
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Fresh Water Tank Leak At Bottom of Tank From 1/8" Hole KJRitchie Fresh Water Systems 25 06-25-2013 08:25 AM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-01-2011 11:51 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
Model Confusion and tank capacity Islander Classic Motorhomes 4 06-18-2006 04:10 PM
