Old 08-28-2011, 05:11 AM   #1
tr0y's Avatar
Las Vegas , Nevada
Fresh Water Tank and City Water ???
A nubie question here, I am in the process of building out the shell of a trailer and am designing the fresh water system, I am a competent plumber, but what I do not understand is the city water inlet vs the fresh water tank and how they work together.
My questions are :
1. How do you go about using the city pressure vs the tank and pump ? Is there a valve / cut off or something I am missing ?
2. If so any suggestions on what inlet is best
3. Does anyone have a plumbing system drawing or design that they would be willing to share ?
T
tr0y is offline   Reply With Quote
Old 08-28-2011, 06:08 AM   #2
x
XXXX , XXXX
T each system has a check or one way valve so that when using either system water does not flow backwards. The water pump has an internal check valve so that city water pressure does not feed back into the potable(fresh) water tank. The city water inlet mounted on the side of the coach also has a check valve attached so that when using the water pump and potable water tank water does not flow backwards through the city water inlet connection.
You can if you desire build into the system a potable water tank fill option. That would require a manually operated valve. Then when connected to the city water you could switch the valve and fill the potable water tank easily before travelling.
wasagachris is offline   Reply With Quote
Old 08-28-2011, 06:08 AM   #3
indy's Avatar
1962 22' Safari
kansas city , Missouri
Images: 22
What I did was to install the city water inlet with a presser reg in behind or after the 12v pump.
works fine.
good luck
Indy
indy is offline   Reply With Quote
Old 08-29-2011, 04:49 AM   #4
tr0y's Avatar
Las Vegas , Nevada
Thanks guys now I understand, with the vent in the water tank I was just not sure how to deal with it
T
city water, water, water fill, fresh water tank
Proper City Water Fill, 30A inlet, etc. Placement? worldinchaos General Repair Forum 5 08-16-2011 02:39 PM
Help-dewinterizing and no water off freshwater tank bonginator Water Heaters, Filters & Pumps 6 06-12-2011 08:37 PM
Water coming out city water inlet mutcth Fresh Water Systems 5 05-27-2011 09:23 AM
Fresh Water Tank mshamilton Plumbing - Systems & Fixtures 4 05-08-2011 02:01 PM
Convert water gravity tank to outside pressure robwok General Interior Topics 15 02-11-2011 12:00 PM
