Old 10-26-2010, 09:03 AM   #1
Lulu's Mommy
ringme13's Avatar
1961 24' Tradewind
Austin , Pennsylvania
Fresh Water Tank
We are replacing the old galvanized fresh water tank with a new plastic one. When we ordered it, the manufacture recommended a place (hole) to put a releif valve near the top of the tank. The old tank had none. Can anyone tell us what we need to put this valve in? Is it really necessary?
Linda Bell
ringme13 is offline   Reply With Quote
Old 10-26-2010, 09:17 AM   #2
x
XXXX , XXXX
Linda you need some where for the air to vent to when you fill the tank with water.
wasagachris is offline   Reply With Quote
Old 10-26-2010, 02:26 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Vent/Pressure relief
If the filling tube is like the one in my Argosy, it has a vent built in. If not, as long as there is space around the hose you are using to fill, it should vent. Much like the gas tank on older vehicles.
Noisy water lines when using fresh water tank Castaway Fresh Water Systems 14 12-17-2010 03:01 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
