Old 09-05-2010, 04:36 PM   #1
clrhflower's Avatar
2010 31' Classic
chesapeake , Virginia
Fresh Water Tank
Greetings,
I'm sure the answer is out there somewhere...but I can't locate it. I need to flush my fresh water tank, anyone know where the plug is located? I have a Classic 2010, 31'. Thank you for your help.
clrhflower is offline   Reply With Quote
Old 09-05-2010, 09:51 PM   #2
Ottawa , ON
Just curious: what does the Owner's Manual say?
Apparently, some of them don't actually have a drain plug. IIRC, you use the electric pump to drain them dry.
Old 09-05-2010, 10:08 PM   #3
2010 27' FB International
Miami , Florida
I have a 2011 International 27FB and the drain plug is a little white valve located below the shore power plug between the two axles. It takes forever to drain. Not sure if it is the same for your model.
gamana is offline   Reply With Quote
Old 09-06-2010, 06:08 AM   #4
clrhflower's Avatar
2010 31' Classic
You know, it's amazing what the Owners Manual does not say.....thanks everyone, we'll go down and take another hard look.
Noisy water lines when using fresh water tank Castaway Fresh Water Systems 14 12-17-2010 03:01 PM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
