Old 09-04-2003, 04:54 PM   #1
Fresh Water Tank
Below is a picture of my fresh water tank after I removed it from my 1967 Caravel. My question concerns the 2 copper lines that are connected to each other by a plastic line. The plastic line appears to be a previous owner alteration of some kind, and possibly the copper lines are also. The tank was connected to the outside fill spout and the water pump. I have no idea what the other 2 lines are for. There is no hole in the floor for any drain or overflow line. Can someone shed some light on this for me?
bpaolini is offline   Reply With Quote
Old 09-04-2003, 04:59 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The flexibable line WAS clear when installed. If you look along the front edge of the couch/dinette ther was a slot that the tube was visible thru.
This is the way you check the water level in your tank
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-04-2003, 05:05 PM   #3
Fresh Water Tank
Thanks so much for the quick reply. I would never have guessed the purpose of this plastic line. I'll have to get a new one I can see through. Thanks again.
Old 09-05-2003, 07:58 AM   #4
bpaolini
Please be advised that the original fresh water tank was gray in color, and failed extensively.
Airstream replaced many thousands of those tanks, in warranty.
I am amazed that any still exist.
Old 09-05-2003, 08:30 AM   #5
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Another member of the Happy Caravel Club
Hi Bpaolini!
You're automatically a member of the "Happy Caravel Owner's Club" just by virtue of having a '67 Caravel. Congrats! See our posts under the 1965-1968 Caravel forum.
My 68 Caravel has a replaced fresh water tank. The new tank does not have a gauge for water level, which is a real nuisance when boondocking. I plan to add one. For now, I and another Caravel owner have to remove the cushions, put a flashlight on the side of the tank, and rock the trailer to see how much water we have left. So I'd seriously look into a nice gauge when you put in the new tank.
Just downstream of the tank my new plumbing has (in this order):
(1) a valve to divert the tank water to the dump, which exits the trailer through a hole in the floor;
(2) a blow-out plug in the water line. This allows me to connect an air compressor to blow out the lines.
(3) a shut-off valve for servicing, or emergencies (I've used this several times already when adjusting the water pump).
(4) a small water filter
(5) the water pump
(6) a small Shurflo accumulator (or pressure tank). This smooths out the flow and reduces pump cycling. I got it for about $37 via Camping World online.
It's all connected with plastic plumbing and there are quick-disconnects in the appropriate places.
Just FYI in case you are re-doing the plumbing at the same time.
-- RL
rluhr is offline   Reply With Quote
Old 09-05-2003, 01:46 PM   #6
Fresh Water Tank
Many thanks to everyone for the info on the water tank. I filled it with water and didn't notice any leaks but it sounds like I should replace it before I put everything back together. Funny, but I thought this would be one of the few items I wouldn't have to replace. O well, I really am having a lot of fun working on this old classic and I really appreciate the information I'm getting from this forum. Airstream owners are great people.
Fresh water tank leak Flex Fresh Water Systems 3 09-30-2004 04:25 AM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 12:37 PM
Problem Filling Fresh Water Tank DaveJ Fresh Water Systems 8 10-14-2003 05:36 PM
Leaky fresh water tank nellie the elephant Fresh Water Systems 3 10-13-2003 02:12 PM
Fresh water tank - slow drip drboyd Fresh Water Systems 5 07-24-2003 07:01 PM
