Old 09-16-2006, 12:30 PM   #1
nilesrob's Avatar
Marietta , Georgia
Images: 12
Fresh water tank
Any thoughts or recommendations as to whether you should store your AS with the fresh water tank full, partial or empty? Not for winter storage (I'll drain obviously), but when storing for a month or two...
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 09-16-2006, 12:41 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Empty for me
I always empty the fresh water tank at the end of a trip. Stored water can get nasty with the extream heat where I live. I open the drain valve at the dump station after I dump my tanks. The rocking and rolling on the way home ensures that the tank is empty.
BTW, is the Big Chicken still standing?
Richard
Old 09-16-2006, 01:04 PM   #3
nilesrob's Avatar
Marietta , Georgia
Images: 12
Thanks!
Kind of as I thought, but wasn't sure.
And yes, the Big Chicken is still standing tall and proud (or something like that!). There is a 10K run up Cobb Parkway on Labor Day (10K Classic), so back when I was running a bit more I would at least go by the Big Chicken - about as close as I have come.
The Slowsky's
WBCCI #1271
Old 09-16-2006, 01:50 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Ditto on Richard's recommendation. I find mine drains best if I have a bathroom cold spigot opened to let air enter the system freely (pump off of course). For some reason my kitchen sink lever tends to rattle closed if I use it.
5 meter Langford Nahanni
Old 09-16-2006, 09:17 PM   #5
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Hello,
We have had trailers, a motorhome, etc. Some have had plastic type fresh water tanks, one galvanized ~ had one plastic type in a sailboat. In the trailers we always empty the freshwater tanks at the end of a trip (or shortly thereafter) and sort of let them air out. Otherwise you get icky tasting water! On our boat it was much more difficult to find fresh water when out at sea.... the marine stores sell a product called "Sweet Water" and it helps to keep the water tasting fresh. But we aren't talking about weeks and weeks here...
Besides, the inevitable leak will appear sometime in the water tank. If it is filled with water it can slowly wick into whatever is nearby without your knowledge until you step on the floor and it is squishy. If you fill and empty you might spot a leak quicker. (Maybe only wishful thinking!)
Good luck! Have fun, and go camping!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
Sanatizing the Water Tank? 68 Suburban Fresh Water Systems 3 10-13-2002 12:22 PM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 02:10 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
