Old 07-02-2013, 07:24 AM   #1
1978 23' Safari
Wausaukee , Wisconsin
Fresh Water Tank
I own a 1978 23' Safari rear bath, 2 bed, 2 axel Airstream. I am unable to locate the drain valve to empty my fresh water tank, can anyone help me locate it?
Larry Pagenkopf
704 604 9783
Biglar0061 is offline   Reply With Quote
Old 07-02-2013, 07:56 AM   #2
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
Larry, not 100% certain, but most 1978 models have the fresh water tank located beneath the floor and between the axles. If you take a look and confirm its there, there will be an inspection/access plate on the bottom of the water tank belly pan between the street side tires
Jeff
AIR: 649
TAC: CA-40
Northern California Airstreamers
Coastalview is offline   Reply With Quote
Old 07-02-2013, 10:14 AM   #3
1978 23' Safari
Fresh Water Tank Drain
I have checked the road side between the axels and under the fresh water fill inlet, there is no floor plate or drain plug nor is there any drain valve, does anyone have another suggestion?
Old 07-02-2013, 10:35 AM   #4
2002 27' Safari
Images: 14
That's puzzling, May have been relocated?
Attached 1978 specifications in pdf. format.
List's all floor plans; 50 Gallon polyethylene water tank
between axles.
AIR: 649
TAC: CA-40
