Old 01-19-2010, 09:08 AM   #1
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Fresh water shunt installed
I finally got around to modifying the water system so that I can fill the '78 Excella (center bath) fresh water tank from city water directly without using a hose to the outside filler. I mounted a 1/2" brass gate valve so that the handle is accessible in the clothes closet. This valve when opened shunts city water into the fresh water pick-up for the pump on the tank side of the filter screen. Got to remember close it when I'm done!
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 01-19-2010, 09:42 AM   #2
If for what ever reason, you allow the water tank to overfill, you will find that the pressure of that tank can buckle the galley floor upwards, about 6 inches, before the water tank ruptures.
Sounds impossible, but it happens.
That's why Airstream did not install that type of valve.
Old 01-19-2010, 10:05 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Make sure you take the outside cap off for venting. The normal vent is not big enough to let out all the air you are displacing with water. You could over pressurize your tank and break the supports.
Michelle TAC MT-0
Sarah, Snowball
Old 01-19-2010, 11:20 AM   #4
2002 19' Bambi
Lafayette , California
Having followed thecatsandi's lead (http://www.airforums.com/forums/f443...e-36450-2.html) in installing an indoor filling system, I can offer a little advice for someone else who might try this. I did not have Andy's warning at the time, but wanted to avoid pressurizing the freshwater tank in our Bambi. As a result, I put a "T" in the freshwater fill hose and connected there to fill directly from city water. I also made a couple of bleed holes in the outside filler which are under the outside cap but not sealed by it. The cap does not truly seal in any case. If I inadvertently overfill, the excess water gushes out the outside filler. Shocks the neighbors in a RV parks sometimes! I try not to overfill, but it happens on occasion.
Tim
Tim A. is offline   Reply With Quote
Old 01-19-2010, 12:06 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Trough Valve, Float Valve: Jobe valves
Hudson Valve Company, Inc.
You can mount the valve in the tank or in a piece of, say, 4" PVC above the tank somewhere, with a vent/overflow that is screened and set up in a way to prevent overpressure damage in the event of float failure.
It's important to have a screen or sediment filter upstream of the valve because otherwise they can stick open.
Old 01-19-2010, 12:13 PM   #6
Excella CM's Avatar
Venice , California
The excella fresh water outside fill is basically open to the atmosphere-it doesn't seal. I notice that when I overfill using a hose, the overflow for the tank handles the excess without any back up in the filler. Ergo, I think I am OK with this. We'll see, I reckon.
Anyone out there with ammeter/shunt experience? johnobuttons Lights - Interior & Exterior 2 08-16-2009 11:40 PM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Water heater & fresh water capacity ESCAPE POD Water Heaters, Filters & Pumps 5 11-14-2007 04:14 PM
New Water Heater Installed Buttercup Water Heaters, Filters & Pumps 14 06-21-2005 02:36 PM
