Old 03-29-2011, 01:13 PM   #1
Muncie , Indiana
Fresh water sensor location - '06 Safari
Greetings:
From searching the forums, it sounds like the CatCon sensor for the fresh water tank on my '06 Safari 25 FB is covered by the belly pan. Is this correct?
If so, can anyone provide a precise location so I could cut a window. Tech support sent me some factory drawings for tank location but they don't show where the sensor is located and I can't spot it from looking in from the sides.
Thank you to anyone who can assist.
Steve
SailorSteve is offline   Reply With Quote
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 07:02 PM
Grey Water Tank Flushes Toilet (to conserve fresh water) LittleRadio Sinks, Showers & Toilets 8 03-28-2011 10:10 AM
1975 tradewinds fresh water tank elkay12 1970-79 Tradewind 2 03-25-2011 08:23 AM
Fresh Water Tank Drain Jack46 2009-2015 Flying Cloud 3 03-06-2011 01:37 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
