Old 05-29-2011, 06:37 PM   #1
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Fresh Water Pump
If I were replacing my fresh water pump, what brand is considered the best? I currently have an Aquajet. It works great but is sometimes loud. I have also looked at Shurflo on line. I'm looking for the best pump out there. Also, please recommend the specific that you think is best.
Thanks, Brian
SuEllyn & Brian McCabe
Old 05-29-2011, 06:47 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
I used a pump similar to this one: Shurflo Smart Sensor Water Pump you see more of the variable speed type these days - when using a small flow of water, the pump runs slower than when there's a large demand, in which case it'll power up!
Our's is fairly quiet as well - but I insulated the mount with lots of rubber grommets, and loosely mounted the input/output hoses as well...
Our pump is mounted in the rear bath, and you can't really hear it up front in the galley - we no longer need 'ear protection' when running the pump!
Water pump installations are one of my pet peeves in RV's! Our old Lance camper's pump sounded like Rosie-the-Riveter was working inside when it lit up!
I don't know why RV Mfg's can't devote more 'engineering' to the water pump system, and keep em' quiet! there's just no justification mounting the water pump to a panel that acts like a drum head to amplify the noise inside the living area!
I know it's a trade off trying to mount the various plumbing systems in a place where it won't freeze in cold weather, but I still believe there's more that could be done to keep the pump 'quiet'...
Ray & Pat; Morada, CA
Old 05-31-2011, 12:43 AM   #3
moosetags's Avatar
Thanks, Ray. That's the very pump that I was looking at.
Brian
Old 05-31-2011, 05:35 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Brian, whatever brand you get (and the one you're looking at is a good one), get a variable rate pump. The (most of the time) slower speed equates to quieter operation.
Old 05-31-2011, 05:49 AM   #5
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
I asked the same question a few weeks ago. This might be helpful:
http://www.airforums.com/forums/f445...ump-77274.html
SilverCottage is offline   Reply With Quote
Old 05-31-2011, 07:08 AM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Coincidentally, I just had to replace our water pump last week.
I brought the trailer home from storage on Friday ready for a weekend trip and found that the existing Aquajet ES pump was seized. The motor just "hummed"
I removed the pump and started to dismantle it. I got to a point where I was afraid of damaging it to dismantle it further as I had no manual or parts diagram.
So I decided to see if I could buy a new pump in order to still get away for the weekend on our trip.
I called three local RV places and no-one had the Aquajet, so I wound up with a Shurflo.
Although rated slightly lower in capacity, it seems to deliver more water than the Aquajet did, and is much quieter - very happy with it.
Mind you the noise improvement may be due to the way I piped inthe new pump.
The Aquajet (very noisy) had a length of flex hose on the outlet, but was direct connected to Pex on the inlet side. I used hose on both sides with the Shurflo.
Incidentally, I subsequently got the Aquajet apart and found the front motor bearing had gotten water in it and was totally seized.
I couldn't find any reference material (parts lists etc) on the internet, and I have emailed Aquatec, the maker - but with no reply after a week.
I will likely just scrap the old one and stick with Shurflo pumps which seem more readily available
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 07:02 PM
Flojet or Shurflo Fresh Water Pump? SilverCottage Water Heaters, Filters & Pumps 8 07-24-2011 02:25 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
