Old 08-08-2015, 04:01 PM   #1
1979 28' Airstream Excella 28
Brooklyn , New York
Fresh water on 1979 Airstream Excella
This motorhome is new to me so I am trying to figure everything out and I don't want to wreck anything. I am at a rv park and I have access to city water. I also bought a pressure regulator and hose so I am ready to hook up. The part I am not sure of is exactly how to do so. If I just hook up the home to my RV and turn on the water won't that fill the fresh water tank? Is there some way to flush the tank because I don't know how long the water that is in there now has been sitting. Is there a switch or some valve that I need to change when I'm hooked up to city water? I am looking for somewhat of a step-by-step here. I've added a photo of what I believe to be the fresh water hookup. Click image for larger version
Name:	ImageUploadedByAirstream Forums1439071271.929918.jpg
Walkietalkie is offline   Reply With Quote
Old 08-08-2015, 08:17 PM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
if the water system was not messed with, you have either external or internal water supply. Once you hook up to an external water supply (yes an additional pressure regulator is highly recommended), your fresh water tank will not be filled, since there are 1-way check valves in place. The same holds true if you use your waterpump, a check valve will keep the water from running out your city water hook up.
to flush the fresh water tank, you need to find the drain valves, close to the water tank. Open them up and let the tank drain completely. Then partially fill the tank and add half a cup of chlorox. if you have the rear bath, your tank should be under the drivers side twin bed. Its a good idea to check if the tank is still mounted properly while you are looking around there.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 02:32 PM
1979 Airstream Argosy Astrobus :: 1979 Airstream Astro Bus shaunamadre Airstream Registry Discussions 1 08-13-2012 11:56 PM
fresh water drain '81 Excella II ole81 Fresh Water Systems 8 09-25-2007 10:41 AM
