03-16-2008, 07:46 PM
2017 27' Flying Cloud
Columbus
, Indiana
Fresh water level while travelling
We are planning a trip soon (a few hundred miles a day) and intend to use the fresh water tank for flushing the toilet only. (We could still have freezing temps here and I REALLY don't want to de-winterize all the pipes, go south, then make DH re-winterize when we return. Which is better...travelling with a half- full tank to cut down on weight while towing or do we fill it to the top to minimize sloshing and weight shifting while traveling?
Seems like this has been discussed but darned if I can find it. Sorry.
Mrs_RedSHED
03-16-2008, 08:01 PM
_
hi mrs'
how are u going to route water to the john but not ALL of the pipes?
and you've gotta send water through the water PUMP to use the john.
which means dewinterizing most of the lines...
IF you really only plan 2 use water for flushing,
carry 1 or 2, 6-7 gallon jugs in in the shower stall or tow vehicle...
and use a small bucket for flushing as needed...
the jug can be refilled in route IF necessary.
just an idea.
cheers
2air'
03-16-2008, 08:04 PM
2019 22' Sport
High River
, Alberta
If you are not worried about increase in tongue weight, and have a tow vehicle with reasonable power, fill it and don't worry about it. Towing with the tank full will lower the centre and gravity should actually improve towability.
Having said that, we typically travel with about 10 gallons in the tank - enough for stops while on the road. I've never detected the water surging in there. Perhaps 80 to 100 lbs is not enough to matter, or maybe the tank design keeps the water from moving around too quickly. I do know what surging water feels like, having experienced it with a water tanker with a 2000 gallon tank half full.
03-16-2008, 08:10 PM
More than one rivet loose
Los Alamos
If the TV and axles will handle it.. Run Full. Water is life.
Michelle TAC MT-0
Sarah, Snowball
03-16-2008, 08:11 PM
Columbus
, Indiana
Here's my theory...
We will only flush the toilet. Yes, the water from the tank will go through the pump and associated pipes on the way to the toilet. Then, when we get home we can drain any extra fresh water from the fresh water tank, pour more antifreeze into that tank then run the toilet 'til we see antifreeze. I suppose there may be a chance for some "bleedover" of water into the early sections of pipe heading to other lines than the toilet but how much really? And would it really be enough to dilute the antifreeze to the point of allowing some freezing? My guess is that it would not.
Mrs_RedSHED
03-16-2008, 08:28 PM
1978 31' Excella 500
Genoa
, Nevada
I bet you'll have to essentially re winterize if you run the water pump with straight water. I suspect there will be enough diluting in spots of the other lines to have a worry. Those lines will pump up with fresh water, maybe you have a faucet driping, and bang there is a diluted spot. I'd look at 2air's idea to carry water to manually flush.
03-16-2008, 08:29 PM
Los Alamos
water is life.
Originally Posted by Mrs_RedSHED
Here's my theory...
You will get water in all your pipes. The air will comress and the antifreeze will dilute. You will have to re-winterize the entire trailer to be safe.
If you get stranded somewhere you can live without food and heat for short periods but water is necessary regularly. This is the reason I travel with the tank full.
Michelle TAC MT-0
Sarah, Snowball
03-16-2008, 08:33 PM
Corona
Here's my theory...
If you put "any" water in the tank and run the pump, you MUST completely winterize the system.
If not, and the temperature goes below freezing for more than a couple of hours, extensive damage to the plumbing system will occur.
03-16-2008, 08:53 PM
_
like cats...
i always travel with a full fresh tank.
it's why i have a trailer. water, food, bed and so on...
IF you try to just use the toilet, how are you gonna flush/rinse the lines later?
do you have a bypass kit at the pump?
if so, it only takes 5 minutes to replace the antifreeze in the lines...
and you could leave the water heater shut off and empty...
rewinterize the lines quickly as u leave the southern location and before returning to hoosier country...
or how about a campers porta potty? or a bucket with bag liners?
so many options for poo!
cheers
2air'
03-17-2008, 11:02 AM
Columbus
, Indiana
Thanks for the advice, all!
Mrs_RedSHED
