Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 07-02-2009, 01:54 PM   #1
Share All's Avatar
Profile:  1999 25' Safari
Rodeo , California
Fresh Water leaks only when pump is on (99 Safari)
Our freshwater tank started leaking, but only when we turn the water pump on. We're not sure where to start looking for the problem. Any help would be great.
Cheryl & Dave.
Check out my introduction to the airstream forums:
http://www.airforums.com/forum...tml#post232718
Share All is offline   Reply With Quote
Old 07-02-2009, 01:57 PM   #2
FLYNCLD's Avatar
Profile:  1962 22' Flying Cloud
Bend , Oregon
Can you tell where the leak is? This will help you isolate the source. Chances are you have a cracked line after the pump, but where does the water come out?
FLYNCLD
FLYNCLD is offline   Reply With Quote
Old 07-02-2009, 02:03 PM   #3
Profile:  1977 27' Overlander
1963 19' Globetrotter
naples , Florida
My guess would be on the line between the pump and check valve,and as it runs down it appears to leak from tank.Dave
easyride is online now   Reply With Quote
Old 07-02-2009, 02:17 PM   #4
Share All's Avatar
Rodeo , California
Great - do we need to remove the tank to check the hose or can it be done from above?
The tank seems to leak from 5 different places - I hope it's just a hose
Old 07-02-2009, 02:34 PM   #5
naples , Florida
I know nothing about the newer trailers,but the pump should be exposed,under a cabinet,in a closet,somewhere,if you don`t know where it is at turn it on and listen.Dave
Old 07-02-2009, 02:54 PM   #6
Share All's Avatar
Rodeo , California
There doesn't seem to be any leaks in any of the hoses.
Is the freshwater tank pressurized when the pump comes on? It seems to be forcing water out. Sitting idle, it has no leaks.
Thanks for the quick replys - I have faith that we'll figure this out together
Old 07-02-2009, 07:19 PM   #7
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
The tank should not be pressurized.
Your pump is located in the curb side closet. Lift the board in the bottom of the closet to access the pump. I once had a leak at the pump that was easily fixed. The pump body itself had loosened up and was leaking.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 07-02-2009, 09:57 PM   #8
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Cheryl & Dave.
You may have a cross water line leaking. I had the same problem with my trailer. It was not the tank but a water line that ran through the tank pan.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Fresh Water Pump Quit scf31 General Repair Forum 2 05-17-2009 07:52 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 08:00 PM
fresh water pump safari 28 Water Heaters, Filters & Pumps 4 02-14-2008 09:42 AM
Fresh water air pump conversion LHall Fresh Water Systems 3 08-28-2007 01:11 PM
Leaks in fresh water drain lines Patsyj1 Plumbing - Systems & Fixtures 5 04-13-2007 07:55 AM
