Old 04-14-2015, 06:47 PM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Fresh Water Leak From Hell
I'm going to need your help with this one.
My 86 Limited is leaking water down the frame rail to the ground. I traced the leak to the 12v pump pressure line where it pressurizes the trailer's "main line" that is the source of water to all the fixtures. The 12v pump pressure line is the top fitting in the first photo. The one with the hose clamp.
The two lines going left are the hot and cold to the kitchen sink.
The forth, and lowest elbow is the suction line from the bottom of the fresh tank to the pump.
My trailer has three drain valves located below the subfloor, next to the frame rail, that allow draining of the water lines. I never use them. You can see them in the second photo.
My leak is in what looks like a tee just down stream of the top drain valve. My leak only happens when I pressurize with the 12v water pump. This line is not pressurized when I connect to city water.
The second photo shows the utter lack of work space to repair this leak. I can't see it from underneath the trailer, and there is no way to get a crimp tool to the fitting.
How in the world is a guy suppose to fix a leak from this line? I may have to gut the trailer, pull the shell, pull the belly pan and fresh water tank to gain access to this fitting. I hope the pictures help explain the dilemma I face. Maybe one of you folks know just how to do this.
David
Name:	1504 Gally Plumbing.jpg
ID:	236320   Click image for larger version
Name:	1504 Leak at Top Tee.jpg
Old 04-15-2015, 05:29 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Today I repeated my testing to see if I could better pin point the leaking fitting. I pressurised the system with city water and dog gone if it didn't leak. I thought the leak was coming from the top tee, but I now think it is coming from the middle one. The middle one feeds the kitchen sink.
These three lines are very close together. I wonder if vibration didn't cause the clamps to rub through. But I can't see down there to determine where the leak is exactly.
I learned the three lines (main, hot and cold) run on top of the fresh water tank from the curb side wardrobe to the street side bath.
Has anyone ever found a "stop leak" product that might work topographically?
Ugh, so disappointing....
David
Old 04-15-2015, 05:56 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I cant say how you will access these fittings, but if the trailer was mine I would consider replacing all I could reasonably get to with PEX while I was in there.
There is not going to be anything you can apply topically to stop the leak.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-15-2015, 06:08 PM   #4
1994 34' Excella
Warren , Manitoba
As J.Morgan says, the best is to replace as much as you can with PEX. Are you able to do it yourself? Pex tools can be bought quite reasonable, and it is easy to work with. I replaced most of the copper in my 1976, and have replaced some on my '94. Take your time, and plan it out, and you should be able to do a better job than the factory!! Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 04-15-2015, 06:37 PM   #5
Wayward's Avatar
Cary , North Carolina
propex may help
If getting a crimper in there is a problem, consider using a ProPex fitting.
Wirsbo, makes a manual expander tool. If those grey lines are PB, you'd need to buy the appropriate brass adapter for transition to pex.
How to Make PEX Expansion Connections
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 04-15-2015, 09:53 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Here is a Sharkbite demo.. you may be able to cut out the 'leak' then use one of the longer devices to branch the distance..
https://youtu.be/FPLdnlVak88
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-15-2015, 10:30 PM   #7
1974 Argosy 20
Kooskia , Idaho
I shudder to remember a similar inaccessible setup in a friend's '87 32' Airstream. As you say, no way to get to the pipes, and very very limited clearances. In his case the valves shown were the source of the leak, but you could not get at them to replace them. His rig was stationary, and after a bit simply stopped leaking through the valve stems. Wheew.
But, about the only thing you can do is to use Sharkbite type fittings and hope to cut the gray polly pipe fairly square to push fittings on to the stubs after the bad things are located. Wish I had a solution for you, but that installation is one of the most difficult ones I have seen for re plumbing.
Old 04-16-2015, 04:15 AM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The hole in the floor is going to have to be longer to effectively work on that.
Once you get over the mental hurdle of cutting your floor, the situation will become much easier.
Old 04-16-2015, 05:03 AM   #9
Skater's Avatar
1995 30' Excella
Bowie , Maryland
There is a Sharkbite adapter that will connect to the gray pipe on one side and Pex on the other. I think it'll fit in your space, but as you noted you have quite a few pipes in the general vicinity, so I'm not sure. Ugh...it doesn't look like a fun situation. I dread finding a similar leak in ours.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 04-16-2015, 05:07 AM   #10
mandolindave's Avatar
yeah sometimes leaks are hard to get at
what aboutůmaking a new " assembly
cut the old where you can get at it.
make an exact replacement
connect the new one with a shark bite
mandolindave is offline   Reply With Quote
Old 04-16-2015, 07:04 AM   #11
1987 25' Sovereign
Oregon , Ohio
As cwf said about shark bite fittings watch the video. I have used shark bite fittings several times in our 87 Sovereign. One of which was under the floor under the sink and they work great.
msmcv51 is offline   Reply With Quote
Old 04-16-2015, 10:44 AM   #12
1976 21' Globetrotter
Anderson , California
There was a class action lawsuit on that plumbing in those years. Forget what it was called. It was used in mobile homes to. I would scab those valves out, and cut out more room and use new fittings as suggested. Sawzall time... !
AirstreamPat is offline   Reply With Quote
Old 04-16-2015, 10:53 AM   #13
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I'd think about forgetting how to access the back or middle lines. Cut them all out starting front to back, then rebuild with pex/sharkbite/pvc - whatever you can engineer that will work- from back to front.
robert claus is offline   Reply With Quote
Old 04-16-2015, 11:18 AM   #14
1996 25' Excella
Tillsonburg , Ontario
When I needed to redo the plumbing on my '89 water filter I used Shark-Bites. Very expensive but totally easy to do. Push on and it's done. and for an extra $1.00 you can get the little tool to release the fitting if you need to take it off. You need to be sure the Pex lines are the same size as the shark-Bites..If necessary just cut the line back at a better access point and fish a new length though the floor space. Your '86 looks jut like my '89 under the sink. Check it first but if necessary I'm betting the lines will have enough flex for the a fitting replacement if you cut it close the the crimped fittings. It seems to me I just used the Shark-Bites to match new Pex to the original Trailer piping
It looks like you can open up the floor a bit around the valves. That won't affect anything structurally.
JCWDCW is offline   Reply With Quote
Water heater hell ExcellaFella General Repair Forum 12 12-02-2012 08:04 AM
I want the silicone to burn in hell Frank's Trailer Works Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 09-14-2007 05:46 AM
Am I about to go to title hell? Alluminatrix Title, VIN & Registration 3 06-04-2006 08:04 AM
Cabinet Latch Hell J-n-A Cabinets, Counter Tops & Furnishings 14 01-03-2006 08:09 PM
