10-21-2009, 07:14 AM
Airstreamin and luvin it
Northwest Panhandle
, The Sunshine State/WBCCI 6637
Fresh Water hose
I am looking into getting a new fresh water hose for outside.I am looking for something I can roll up really easily and not have to worry about looping the hose up any more.I am just getting tired of doing this all the time now.I end up putting it in plastic bags so if there is any left over water in the line it does not run out into the floor.I have seen one that rolls up onto a wheel and it seems pretty good but it is really big.Anything that is small and compact?Any suggestions or what have you all done to make life easier.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
10-21-2009, 07:34 AM
Greeeneville
, Tennessee
Steve, I made several lengths of hose and installed brass ends into it for my own perfect hose. I made a 4 ft length to go from the water hydrant in a camp to my filter, and I have a 6 ft section, and also a 10 and a 20 foot section. These are made of clear, braided 5/8" with brass fittings. These hose lengths have served me well for many years.
Kevin with Baity the Lab/Pointer //------AIR # 7303------\\ WBCCI 17109 visit my restoration blog at:
10-21-2009, 07:42 AM
2018 27' Flying Cloud
Panama City Beach
Steve, I coil up my hose when breaking camp and then put bungees around it to keep it in a tight coil. I then screw the ends of the hose together so water doesn't spill out while in storage (and too keep bugs out).
Russ and Linda
2018 Flying Cloud 27'
2012 F250 Powerstroke 6.7
AIR#24440 WBCCI#11740
10-21-2009, 07:57 AM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
I have one of those roll up hoses. It's 25' long, and rolled up it measures approximately 14" x 14" x 1 1/2" thick. It rolls up flat and squeegees the water out. The one you have pictured seems pretty compact. There are several kinds out there. Just make sure you get the RV/boating type. I use mine as a back-up and as an extension to my regular hoses which I keep coiled up inside a waterproof nylon bag.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
10-21-2009, 11:28 AM
_
Originally Posted by Devoman
I am looking into getting a new fresh water hose for outside.I am looking for something I can roll up really easily...
hi devo
the 'roller hoses' are great for extras, back up, reaching distant source and so on...
but LOUSY for everyday use.
the fittings are weak the hose is thin, the FLOW is slow, they are MORE prone to mildew inside, and so on...
____________________
the permanently coiled hoses have really good brass fittings and are durable and compact.
but the narrow size limits flow/pressure. (for some this is a good thing)
but THIS STYLE have been used the most, is quickest to stow and drain and most durable for daily use.
CW sells these in 25s and 50s in 'blue' drinking water safe color...
_____________________
like 'hobby i cut a quality rv/drinking water hose into sections and added brass ends.
this lets me use only enough and add inline filters easily.
with ANY of these hoses the issue of mildew and bacteria growing INSIDE the hose is still present.
so the hoses need to be sanitized from time2time and the ends COVERED to avoid critters and boogers getting inside.
______________________
disclaimer:
i carry ~175 feet of hose including 2 of EACH of these (roll up, coil, standard) and a 'spare' brand new/unused/packaged hose....
just in case
cheers
2air
10-21-2009, 12:04 PM
Normal
We bought a 50' permanently coiled hose before this last trip, and it was one of the best decisions we ever made. Water pressure isn't as good, but certainly adequate, it takes up less than half the space in our small rig and is just so much less annoying than the regular hose. Coiling that thing and getting it back into its' cubby, especially when cold, was a royal pain. We continue to carry a 5' hose for fresh water fill.
10-21-2009, 01:03 PM
2004 25' Classic
Prescott
We have 3 water hoses, one is 10' and the other two are 25' ea. All are coiled up with the ends screwed together and put on top of the propane bottles under the lid. Usually all we need is the 10' and it is very easy to coil up. Once a yr. I take them out and put them in the tub with some water and chlorine to soak for a while.
10-21-2009, 02:00 PM
Northwest Panhandle
New lines
I am needing some new ones.These look pretty beat up now.Any more suggestions on what everyone uses.Also...What is a good water filter to use.
10-21-2009, 02:25 PM
_
10-21-2009, 04:33 PM
Northwest Panhandle
Originally Posted by 2airishuman
now u r getn lAzE...
I know.sometimes I get like that.
Thanks for the links 2Air.
What about the quick disconnects.I had some break on me in the past.What it had broke was the seal because when I would clip them together it would leak really bad.What do you all use that has worked well with the hoses?
And what type of water hose connectors did you all use to put them together.Plastic,Brass,Stainless?
10-21-2009, 04:46 PM
Northwest Panhandle
Hose
What about one of these.You could put one or two of these in a small box and not worry about taking up much room.
EZ Coil-N-Store Drinking Water Hose - 88-1378
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
This type of quick disconnect has worked well for me:
2005 Bambi
1968 Trade Wind
WDCU
10-21-2009, 06:07 PM
Northwest Panhandle
connector
10-21-2009, 06:21 PM
2021 27' Globetrotter
Saint Louis
, Missouri
I bought some of these at a home-show in St. Louis. I use the big one to store a 25' 5/8" fresh water hose. It works out pretty well.
Dennis
BRN #20321 Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
10-21-2009, 06:32 PM
I bought some quick connects from McMaster Carr this past spring.
I ordered part number 6537K65, and 6537K93 brass quick connects. They make the connect/disconnecting process very easy.
William C. Swinney
