Old 12-19-2011, 08:01 PM   #1
rideair's Avatar
fresh water filler neck
Found this fresh water filler neck on ebay, looks like it would be a nice clean look for an Airstream.
Cast Stainless Steel Boat Water Tank Deck Fill w/ Key 30 Degree Neck 1.5" Hose | eBay
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 12-19-2011, 08:50 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
I put something like this on our Tin Pickle; it replaced a rather ugly broken plastic POS filler door. I did need to fit an additional external vent since the original door incorporated a (small) vent.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 12-19-2011, 10:04 PM   #3
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I used almost identical ones on both my '48 and '49 Boles Aeros. Also used a very similar one for the electrical access on my '48. Makes a waterproof seal. Almost flush with the surface so it does not get hung up in the brush on the back roads.
Sam
samb is offline   Reply With Quote
Old 12-20-2011, 05:09 AM   #4
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
We also thought it was a great idea in our 1960 tradewind to cover up an ugly hole where the previous water filler had been!
http://1960airstreamtradewind.blogspot.com
Love. You can learn all the math in the 'verse... but you take a boat in the air that you don't love... she'll shake you off just as sure as the turn of the worlds.
2vets is offline   Reply With Quote
Toilet Fresh Water Valve Leak perryg114 Sinks, Showers & Toilets 7 10-11-2011 06:41 AM
External Fresh Water filler spout pickerdd Fresh Water Systems 3 08-31-2011 01:56 PM
Fresh Water Tank and City Water ??? tr0y Fresh Water Systems 3 08-29-2011 04:49 AM
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 07:02 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
