Old 01-31-2012, 04:23 PM   #1
1997 28' Excella
Sioux Falls , South Dakota
Fresh water fill removal & replacement
I have a '97 classic 28 and the fresh water intake hose has a leak. I need to replace the hose. Is there any easy way to work on this? Have tried getting in through the closet floor, but the hose goes through the wheel well so that doesn't help. When trying to remove the outside fill box, it seems to be glued in with foam tape. What to do?
thefiddler is offline   Reply With Quote
Old 01-31-2012, 06:00 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
I believe it (Fill Box) was "sealed" with adhesive foam tape to prevent water leaks between outer and inner skins.. May even have a couple of rivets holding it in place.. There is no really easy fix.. You can try working behind or under other interior cabinets to get to space above wheel wells, but that might be worse. Removing fill box and planning to re-attach may be best alternative..
You might try using "Search" tab in blue bar above, and use terms like "water fill box repair" and see if others have had to solve problem ahead of you...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-01-2012, 08:37 AM   #3
1997 28' Excella
What I've done is remove the fill box. Really stuck on, but got it out. Thanks!
Fresh water tank drain valve replacement lboyd Plumbing - Systems & Fixtures 21 01-10-2015 06:04 PM
Fresh water fill funnel thingy needed. Phrunes Fresh Water Systems 4 11-21-2011 08:49 PM
Removal of 1973 fresh water tank Belegedhel Fresh Water Systems 6 08-05-2011 07:32 AM
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 07:02 PM
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 10:46 PM
