07-04-2012, 10:07 AM
1965 17' Caravel
Birmingham
, Alabama
Fresh water fill port vent?
The cast aluminum fill port on my 65 Caravel has a hole in it. It is 1/4 inch in diameter. I guess this is an air vent? It looks like part of the original casting. Problem is, it's located on the underside and water runs out when I go to fill the tank. Does anyone else have one of these vent holes? Is there a plug or screw I'm missing?
Bill AKA cosmos
07-04-2012, 10:09 AM
1977 Argosy 24
Milltown
, Wisconsin
How about a picture of what you have?
07-04-2012, 11:07 AM
Corona
Bill AKA cosmos
The tank is supposed to be fill by taking that cap off, inserting a water hose into the neck, and slowly fill the tank, until water flows out of the top of the filler neck.
That's how it was designed.
07-04-2012, 11:31 AM
1972 25' Tradewind
McHenry County
My '67 had a vent in the cap. The filler neck had casting seams but nothing that looked like a cast in vent port.
Vent on the 72 is completly different with a vent on the top. Don't think a vent on the bottom would make any sense.
Pics would be good.
Tom
07-04-2012, 12:28 PM
1968 28' Ambassador
Cedaredge
my 68 also have a vented cap. I got a new one from Andy at inland RV. Show us a pic.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-04-2012, 12:47 PM
1977 Argosy 24
Milltown
, Wisconsin
Bill AKA cosmos
Was that originally a pressure tank system? My 64 Avion had a round aluminum tank with a drilled and threaded hole in the bottom side of the fill neck also. The cap had a hole in the center of it with a schrader valve stem from a tire in it. I believe the tank was filled about 3/4 full with water and then pressurized with air to move the water to the faucets. I wonder if the hole in the neck was for a pressure release of some sort to keep the tank from being over pressurized.
07-04-2012, 09:05 PM
1965 17' Caravel
Birmingham
, Alabama
I will take a picture. Filling with the hose end makes sense, as the hose goes beyond the hole. I think this is the first year for the pump - type tank instead of the air pressure tank. I installed a new tank and inlet/ outlet pipes and hoses. I rebuilt the original Parr pump. I have the original aluminum fill port casting and cap. I plugged the hole in the filler neck with part of a chop-stick.
I understand the need for a tank vent so air can get in as water goes out. So I had already added a vent line to the tank plumbing.
If no one else has this vent, maybe it was one of the transition features going from pressurized tank to pump tank. I'll just use my plug for now I guess.
Thanks for all the good responses!
Bill
07-04-2012, 09:40 PM
1977 31' Sovereign
1989 34' Excella
Johnsburg
There needs to be a small hose from the tank to the vent port in the casting. This allows air to leave the tank as the water flows down the main hose to fill the tank. If you push a hose into the fill port and turn it on full blast, it will pressurize the tank and blow the sides of it out, if you do not have the second vent line. You need the vent open and fill the tank at a reasonable rate.
07-05-2012, 06:30 AM
1965 17' Caravel
Birmingham
, Alabama
Here is a link to a picture of the water- fill.
https://skydrive.live.com/redir?resi...GsaWryn38qB4Zk
You can see my wooden plug. This is redundant since my tank plumbing has a built- in vent/overfill going to the drain line thru the floor. The Caravel owners manual says to fill with fresh water using a hose or bucket. But water runs out of the hole if I fill with a bucket.
Bill
07-22-2012, 09:47 PM
1965 22' Safari
Woodside
Is there a source for replacement fill necks? Mine is cracked at the flange and I'd like to replace it.
Chris Shaw
07-22-2012, 10:16 PM
1968 28' Ambassador
Cedaredge
Chris Shaw
check with inland RV they have the caps and might have the necks.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-23-2012, 05:29 AM
1965 17' Caravel
Birmingham
, Alabama
I've seen them on eBay ocaisionally. You may find that this small part can be easily weld repaired by a competent aluminum welder. Especially if it's only the flange and there is no leak.
07-23-2012, 06:13 AM
Hollis
, New Hampshire
Chris Shaw
Coming soon to the VTS website
Cast Water Fill Neck & Cap
07-23-2012, 09:09 AM
1965 22' Safari
Woodside
Thanks everyone, I'll repair mine while watching for a used one or the new one coming from VTS.
07-23-2012, 11:34 AM
Corona
New machined caps have been available for several years.
