Old 08-21-2016, 02:19 PM   #1
Peterborough , New Hampshire
fresh water fill on my 1071 AS
I will try to attach a photo, but I can not open my fresh water tank intake. Something has broken off of it and I don't even know if it screws in ( I assume it does), but I cant get it open and don't know how to even begin.
terricrowe26 is offline   Reply With Quote
Old 08-21-2016, 02:19 PM   #2
1971
Old 08-21-2016, 02:22 PM   #3
Here is a pictureClick image for larger version
Name:	ImageUploadedByAirstream Forums1471810925.685134.jpg
ID:	269692Click image for larger version
Old 08-21-2016, 02:37 PM   #4
2016 23' International
Salem , Oregon
Fresh water door
I would simple remove the four screws to remove the plate. It appears you may have a screw in plug and part of it has fallen apart. Once you have taken the plate off I am sure you will see the problem.
Most likely someone makes a replacement.
Dave
NoResults is online now   Reply With Quote
Old 08-21-2016, 02:40 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You will have to drill out the 4 rivets. Use a 1/8" drill bit. Don't go too deep.
Old 08-21-2016, 05:43 PM   #6
Gainesville , Florida
Can you just pry it open from the bottom?
Old 08-22-2016, 12:02 PM   #7
1973 25' Tradewind
Redding , California
My 73 looks different, but that looks like it twists off and the handle is broke off, doubt it will pry off. You might get a flat screw driver, or a flat chisel and place it on the left side of that ridge and tap it with a hammer counterclockwise to try and unscrew it. If not, I agree with TG Twinkie (interesting name )., Drill out those rivets, go from there. Someone with a 71
Leadvox is offline   Reply With Quote
Old 08-22-2016, 12:33 PM   #8
I picture I saw of the same thing shows it pulling straight out, like a spout. An Alum replacement is $188. It looks a lot better but I don't know if it will work. It says for 70's and 80's models. What else will I need? I am going to be replacing all the plumbing this winter with pex, replacing the black water tank to a gray water tank. Should I just wait until I am doing all that anyway. I was hoping to be able to use my AS this fall, but the more things I find, the harder it makes it. We are in NH and go to the Whites for hiking. Many of the Campgrounds don't have hookups and without being about to bring water with me, that is another problem.
Old 08-22-2016, 12:46 PM   #9
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
Definitely, pulls straight out.
fwjumper is offline   Reply With Quote
Old 08-22-2016, 12:49 PM   #10
Boxite's Avatar
2008 22' Sport
Run a screw into it and use the screw to pull it open.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-22-2016, 12:54 PM   #11
fwjumper's Avatar
1998 34' Limited
What has broken off was used to pull on and to lock it if you wanted. Drill a small hole in it, approximately in the center. Screw a stainless sheet metal screw (about a #12, 1 inch long)in about halfway. Pull on the screw (with pliers if your hand won't do it) to open. Push straight in to close. Replace it when you get ready. They do get brittle. If you do get it open and want to lubricate it, get some faucet grease at the big box or hardware store. It is made for use in potable water faucets and won't foul your water supply. If the tank hasn't been used in a while, I would want to sanitize it with bleach solution. (Unless you don't drink it or brush your teeth with it.)
Old 08-22-2016, 02:02 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Have you tested the water system by connecting city water. You may have leaks. So have someone on the inside checking. There may be low point drain valves which will need to be closed.
I would open a faucet while testing to reduce the amount of pressure while looking for leaks. Close the faucet a little bit at a time and keep checking for leaks.
Good Luck
Old 08-22-2016, 08:07 PM   #13
HankO's Avatar
1997 28' Excella
Eden , Utah
I had a similar cover on my 1990 camper, and it pull out. It probably at one time had a small chain or string that hooked to the bottom nub to keep the cap from falling on the ground. These things stick and need to be worked back and forth / sideways, to break loose. If it were me I would put two self tapping screws preferably stainless steel and use a screw driver (or some similar item) wedged between the screws and work it back and forth until it breaks loose, then pry it out and replace the cover.
HankO is offline   Reply With Quote
Old 08-23-2016, 04:00 AM   #14
I love this forum and all of you. Thank you. Without this I really wouldn't get anywhere!
Can water heater fill from fresh water tank? phann Water Heaters, Filters & Pumps 14 02-04-2018 01:10 PM
Noobie - how to fill fresh water tank? Bohemian Fresh Water Systems 26 10-18-2016 01:51 PM
Fresh Water fill from City Inlet question Distantdrummer Fresh Water Systems 7 07-15-2010 05:38 PM
Fresh water tank fill jfowler218 Fresh Water Systems 4 04-21-2009 07:36 PM
Fresh water fill Safari Tim Fresh Water Systems 6 05-20-2007 03:50 PM
