Originally Posted by cwf
Howdy.. I need to remove the Fresh Water fill door. After removing the screws I am gently prying.. without much success... will try adding heat...
On our 34' 1999 it appears the water fill plumbing is routed between the outer and inner fender (inside trim) well.
Has anyone accessed these items on a similar trailer?
Channing,
Seems like I am always seeking your advice. Since we have the same 34' trailer it seems that we have very similar repairs that are necessary. I appreciate all of the good advice and information you have shared.
The water filler hose is leaking on my 34'. I enlarged the access door so that I can see where the hose connects to the fitting that is screwed into the fresh water tank. The leak is just above the clamp. My intention is to remove and replace the hose. To do that I need to remove the filler door first.
I've removed the four screws that hold the filler door. Then I slid a putty knife into the perimeter all four sides, cutting through a two sided tape and the caulk that was around the perimeter. I've pried fairly hard but the filler door will not budge.
Did you successfully remove the door? Did you replace the filler hose and the vent without removing the tank cover?
I'm wondering if you have any advice to share.
Thanks!
