Old 05-11-2011, 04:18 PM   #1
withidl's Avatar
2002 31' Classic
Houston , Texas
Fresh Water Drain Valve Wrench
A recent poster asked how to turn the stiff plastic fresh water tank drain valve without breaking off the rather flimsy plastic handle.
The following photos illustrate a simple “wrench” I fabricated from a piece of scrap aluminum channel (3/8 inch outside width; 1/16 inch wall thickness) which can be purchased from any hardware store. The inside of the channel has an “almost” interference fit with the valve handle such that it supports the entire handle surface to not allow flexing and stressing of the plastic handle while clearing the frame rail. Just simply cut to length (mine’s 8 inches) and it’s done. If you’re a perfectionist you’ll round and smooth the corners, but that’s just me.
Name:	Water Drain Valve Wrench1.jpg
ID:	129632   Click image for larger version
Name:	Water Drain Valve Wrench2.jpg
Name:	Water Drain Valve Wrench3.jpg
withidl is offline   Reply With Quote
Old 05-11-2011, 06:39 PM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Nice - this will help a lot of folks avoid the dreaded "oh, No" moment.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-11-2011, 06:53 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Great idea, thanks.
Brian
SuEllyn & Brian McCabe
Old 05-12-2011, 04:16 PM   #4
greatlakes's Avatar
2004 25' Safari
N/A , Michigan/Florida
Thank you, pmclemore, a simple solution to an annoying problem.
BTW, I received the replacement valve and I just figured out that the tab does not have to be turned all the way forward to close. It closes as the tab points away from the trailer and opens pointing backwards. So, less turning to do and less chances of breaking it. Regardless, I'll try your aluminum channel idea for less effort.
___________________
Frank
2004 25' Safari
2010 4x4 Ford EB Expedition
greatlakes is offline   Reply With Quote
Old 05-12-2011, 06:17 PM   #5
Ready-to-Travel
pmclemore's Avatar
Thanks for the credit, greatlakes - but the credit goes to our new best friend withidl.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Old 05-13-2011, 04:44 PM   #6
withidl's Avatar
2002 31' Classic
Houston , Texas
Pat
I appreciate the "re-direct", and I need ALL the friends I can accumulate.
Old 05-13-2011, 07:31 PM   #7
Ready-to-Travel
pmclemore's Avatar
Keep providing great assists like this one, and you'll be beating us off with a stick.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Fresh Water Tank Drain Valve greatlakes Fresh Water Systems 28 08-09-2011 11:54 AM
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 07:02 PM
Fresh water drain AirEPotter 2011 - 2015 International 11 05-04-2011 02:34 PM
Fresh Water Tank Drain Jack46 2009-2015 Flying Cloud 3 03-06-2011 01:37 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
