Old 10-05-2012, 12:43 PM   #1
Winetripper
2007 25' International CCD
Santa Barbara , California
Fresh water drain valve replacement
I like to start out with a full tank of FRESH water from home - some of the sources on the road are a little suspect, including the one that completely clogged my hose-end filter, which I was very glad I used.
This means draining the tank when I return. The plastic drain valve is very tight and difficult to open. The handle wants to bend and I have to be very careful not to force it. If it breaks I'm in trouble.
Has anyone found a good reliable replacement? The Camco ones that come up on a web search look just as weak. Is there a brass alternative?
I don't want to try removing the one I have until I know what I'm going to put there, so your assistance will be valuable. Thanks!
1 Guy, 1 Gal, 1 Golden
Retirement isn't.
Winetripper is offline   Reply With Quote
Old 10-05-2012, 02:28 PM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Probably if you search tank drain I remember someone on here replacing the plastic valve with a regular brass valve. Just remember it will be in a very vulnerable spot if its between the tires if its like most. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 10-05-2012, 03:41 PM   #3
Ag&Au's Avatar
Port Orchard , Washington
Here is one thread, but I know there are a bunch more.
Ken
http://www.airforums.com/forums/f163...ent-86063.html
Old 10-05-2012, 07:08 PM   #4
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Before you go and replace the valve, try some food grade silicone spray on it. It's in a tough spot but a good, occasional dousing of the silicone should make a big difference.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
sandlapper is offline   Reply With Quote
Old 10-05-2012, 07:09 PM   #5
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I think that you will find thay AS used a soft neoprene hose between the tank and the valve. These hoses colapse and the drain does not work even when you can open it. You can take that value apart. The plug handle should push up and out. I think you will find the solution is to cut a 6x6 hole in the tank cover bottom to service the hose and replace the vavle with a boiler drain petcock. (or hosebib)
Bigventure is offline   Reply With Quote
Old 10-05-2012, 10:41 PM   #6
withidl's Avatar
2002 31' Classic
Houston , Texas
Try This "Drain Valve Wrench"
I previously posted a wrench for the drain valve which may negate your need to R&R the plastic one: http://www.airforums.com/forums/f443...nch-77246.html.
withidl is offline   Reply With Quote
Old 10-06-2012, 01:04 AM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, CrawfordGene replaced his drain with a brass valve.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 10-11-2012, 04:19 PM   #8
Phoenix , Arizona
When I changed my drain, I used a 3/8" brass ball valve.
M2HB is offline   Reply With Quote
Old 10-11-2012, 04:26 PM   #9
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Make a Drain Valve Wrench...
... just as Withidil suggests.
It just takes a few minutes and works like a champ.
I made mine by cutting a slot in a 3" PVC pipe nipple.
Voila! There is nothing wrong with the valve that 3 inches of leverage won't solve.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 10-11-2012, 05:55 PM   #10
dznf0g's Avatar
Oswego , Illinois
John
X2. I was going to make the wrench, then go replace with brass, but two applications of the silicone and it has operated smoothly for almost 2 years.
-Rich-
Old 10-11-2012, 07:00 PM   #11
Ag&Au's Avatar
Food Grade Silicone?
Someone explain this to me.
I realize some people have silicone in their bodies. However I believe it is cased in something less reactive. As I understand, when the casing brakes it is a health hazard. How can there be food grade silicone.
To me the term makes about as much sense as food grade Drano, or food grade gasoline.
Ken
Old 10-11-2012, 08:05 PM   #12
r carl's Avatar
Lin , Ne
Ken
It must have been food grade teflon that they put on those millions of crappy fry pans. At least you wont ingest silicone from your drain valve.
Old 10-11-2012, 08:15 PM   #13
Ag&Au's Avatar
I always crawl under the trailer to drink out of the drain valve, so I get water that hasn't been exposed to the plastic pipes.. Doesn't everyone??
Ken
Old 10-12-2012, 08:05 AM   #14
sandlapper's Avatar
1993 34' Excella
I don't know the technical stuff as to why it is called food grade, I only know that compared to most silicones the food grade is not oily and has no smell. It is cleaner. I'm not ready to spray my frying pan with it but you could. I'll dig out my can and post the name a bit later.
John
John
Old 10-12-2012, 08:09 AM   #15
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
do people actually drink the water from the tank? We carry bottled for drinking. Not worried about the health hazards, but the plastic taste is a bummer.
A Blog from the Devil's Triangle
https://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 10-12-2012, 08:22 AM   #16
sandlapper's Avatar
1993 34' Excella
We have the drinking water filter that is mounted under the sink. It does a great job making the water taste good. And after 5pm I filter mine again through some good single malt, making it taste really good.
John
Old 10-12-2012, 08:24 AM   #17
dznf0g's Avatar
Oswego , Illinois
Yes, and I have noted no plastic taste in the 3 RVs I have owned. Maybe we're just less sensitive.
-Rich-
Old 10-12-2012, 08:46 AM   #18
Ag&Au's Avatar
Believe it or not there are multiple threads about that very subject.
I have drank water out of an RV tank since 1956. Never had a problem or even given it a thought. Ours doesn't taste like plastic, it tastes like water. We generally drink and cook using water filtered by the under sink water filter, but this is our first trailer that has that feature.
Ken
Old 10-12-2012, 09:42 AM   #19
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
John
Molykote 316 Silicone Release Spray
SilverGate is offline   Reply With Quote
Old 10-22-2012, 07:28 PM   #20
r carl's Avatar
Lin , Ne
Ken
Ummm, do I dare ask where you go to eat?
