Not familiar with the PVC type petcock on A/S, but on the pool at my old house, I used to use baby oil on the PVC valves for the solar panels. Worked like a charm.
Yea mine is a bear also. The problem is getting it started since the little tab sits against a flat surface. There is no easy way to get your finger behind the tab. Sometime a small screwdriver just to pry the tab away far enough is all you need to do. Once you get your finger behind the tab you can apply the force necessary to open it up. I haven't had to take the lubrication route at this point.
Jack
Jack Canavera
STL Mo. AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
On the '03s (at least the Bambi), those type valves are gone. They use a smaller version of the valve that connects to a house toilet, except these move very, very smoothly. No binding at all.
Mine has a PVC ball valve. There is an elbow and the ball valve hangs right under the tank woth a big handle. Very easy to operate, but I worry sometimes about it hanging so low.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
I'm sorry I didn't describe the problem clearly enough. The petcock I'm talking about is the one under the trailer to drain the fresh water tank for winterizing etc.
Sorry,
SkipJ
After many painful fingers, different lubricants, and extensions to increase torque, I had AS replace it when we were last in JC - works pretty smoothly now.
__________________ Steve&Susan 2005 28' CCD, 2002 Silverado-C1500, Equal-I-Zer Empty Nesters - spending our money on OURSELVES for a change!
