Old 09-28-2014, 12:50 PM   #1
Phoenix , Arizona
fresh water drain location on 16' Bambi
A newbie question, where is the fresh water drain on the 16' Bambi? I found two plugs near the sewage drain. Are they the drains? And why two?
Thanks.
jdmap1 is offline   Reply With Quote
Old 09-28-2014, 04:08 PM   #2
2004 16' International CCD
Chicagoland , Illinois
Don't mess with the ones that you found. I believe they are for the black/gray tank.
On my Bambi the valve to drain the freshwater tank is mounted on the floor under the dinette seat in front of the tank itself. The drain drops straight thru the floor under the road side front corner.
Airrogant is offline   Reply With Quote
fresh water drain valve location '72 globetrotter? ssfletch Fresh Water Systems 6 09-28-2014 07:02 PM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
1993 - 34' Fresh Water Drain Location willyd 1993-1997 Limited 1 01-26-2009 07:43 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
